Question about Craftsman Garden
Lt1000 model 917.274351
Where is oil filter located
How much oil does it take to change the oil in the lt1000 17.5 hp craftsman riding mower?
The best way to do this is to check that the unit is full of oil. Then measure what comes out when you drain it. Put this amount back in and you should read about a pint less than you need. That is because that is what is in the filter that you changed when you drained the oil. You are going to change the filter, right?
Fine tune the top up and you are good to go.
Feb 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lt1000 18hp Briggs and Stratton engine stalls after running for a short while and will not restart until cooled off. good gas and clean filters
Go to your local auto parts store and buy an inline spark tester if you don't have one.
Next time the engine stalls, use the inline tester (goes between spark plug and plug wire) to see if there is spark. If there is no spark, then most likely the engine has overheated the ignition module. Check the oil level, low oil level will cause overheating. Check the cooling fins, clogged fins will cause overheating. The ignition module will need to be replaced for a long term repair. Make sure to correct any overheating condition also. When/if you replace the module, it is a good idea to inspect the flywheel key. It is located under a very large nut on top of the engine. If the flywheel has rotated on the upper crankshaft, the flywheel key (aluminum) will have been damaged. This also can cause an overheating situation.
Oct 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 riding mower with 18hp B&S engine. Mower acts like the battery is almost dead. Will try to turn over but doesn't seem to have the power to cycle the engine. New battery, starter,...
There is a compression release device on the cam shaft to allow the engine to spin easier when starting. This is likely the culprit because the starter isn't strong enough to push the engine past full compression. The fix is to replace the cam shaft.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a LT1000 starts fine and then stalls after a short run, I have clean fresh gas, new fuel filter, oil change, battery, and spark plugs
There is a kill switch under the seat that makes sure you stay in the seat if the mower is running...my bet is that the switch is malfunctioning and the vibration of the motor is causing it to short out...get a new switch, they can't be that much...
heatman101
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
On a 1994 Honda Accord is the oil filter located on the passenger or driver side of the engine?
Fig. 1: Oil filter and drain bolt locations on 4-cylinder models 86801050.gif
Fig. 2: Oil filter and drain bolt locations on 6-cylinder models 86801051.gif
Jun 28, 2010 | 1994 Honda Accord
Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Apr 03, 2010 | Garden
Tractor starts then stop running
It will either be the stator that needs changing or the carb needs to be pulled off and cleaned
Jul 01, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
54 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
