Question about Brother DCP-J125
Brother printer head problem clening
Shows print unable 4F
The LCD displays an error code with problem with Printhead. To fix Brother Printer Error Code 4f go through eh 2-3minutes read of blog either or connect o right experts for assistance. The causes to this error is connection failure of the carriage-head flat cable or head flat, Print head defective, Power supply PCB defective, Main PCB defective. Looks of the causes and move ahead with the issues. Brother to help you settle on your printer obtaining choice, read the Brother Printer Error Code 4f surveys and evaluations. Impart following Model Brother Printer such as:
    ·Brother multifunction printers
    ·Shading laser printers
    ·inkjet Printers When you are searching a Brother Printer answer for a home used or home office, little or medium business, or substantial business or workgroup, the impartial Brother Printer tech experts direct you towards the right printer solution. Connect to Brother Printer Support Number for proper and one to one assistance with experts.
Brother Printer Technical Support Blog News 1 800 213 8289
Dec 28, 2015 | Office Equipment & Supplies
How to clean printer head on brother MFC-J625DW
every brother has the ability to clean head, open control panel, open add printers, check your brother properties and click clean heads.
you also should have keypad access on brother to clean heads.
suggest you read the manual for proper code sine most Brothers have different codes.
Feb 07, 2015 | Brother MFC-J625DW Wireless All-in-One...
Clean head nozzle check
Sir/Madam
Please Check How to Manually Clean the Nozzles on the Print Heads of Brother GT...
In case Still Having Problem Then Follow Us For Brother Printer Problems For On : Brother Printer Support
Jan 21, 2014 | Brother MFCJ220 All-In-One InkJet Printer
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
I get streaks across colour copies and prints on my gestetner dsc460. How to clean heads or fix problem
replace clening drum plad
clen the drum unit
may be their is a duste on the meirror if is proplem hapend when you useing copy
Jan 31, 2011 | Gestetner DSc460 Copier
Picture comes out blue
Assuming the cartrige has ink in each tank, Go into printer software and access Print head clening and follow instructions.
By accessing print head clean it will do a test print of all colours and if one has run out it will be blank.
Dec 03, 2009 | HP Photosmart A526 photo printer
Unable to print
i think your printer needs a clening
i hope i can solve your problem
Sep 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer is saying need new toner cartridge when putting in a new
Try clening the printhead with collin spray..
works for many
fame !
Jun 23, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printer wont print!!
Has it printed correctly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Brother Multi-Function Center MFC-240C...
Color doesn't print in true color.
It may be the printer color settings in your printer properties. May be set to draft. Change it to best or normal.
Go to Control Panel> Printers and Faxes> right click on your printer's icon, go down to properties. There unerd advance, you can do a head cleaning. Under color management, set it to automatic.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | HP DeskJet 940c InkJet Printer
Brother DCP-J125 Logo
14 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
