Service manual on a carrier screw compressor model 06na
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: where can i find a
go to Carrier's we dite and search in the commercial seaction for the manual. Thanks for using FixYa and have a Merry Christmas/.
Posted on Dec 25, 2008
Compressor capacitor carrier model #50SS060-311
What you'll need to do is contact a Carrier dealer with the product, model, serial numbers. Or get the compressor model number and call a good dealer for that make of compressor.
Mar 31, 2017 | Carrier Heating & Cooling
Carrier model 38tdb air conditioning unit kicks out the 40 amp breaker. Also moisture under compressor unit outside. What is problem?
What breaker? The breaker for the condenser? Likely have a compressor shorted to ground or drawing locked rotor amps. Easiest way to tell is make sure breaker off, unhook compressor wires from contactor. Turn on breaker and turn on machine. If the breaker does not trip, obviously problem with compressor
Jul 14, 2016 | Carrier Heating & Cooling
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Error code 112. what is the problem?
Hi Pramesh
Not a normal carrier code, there may be a point between the 1.12 or 11.2
1. xx normally compressor 1 fault
2. 1.12 is compressor 1 condenser entering water thermistor fault, the unit will continue to run
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/30g,h-3t.pdf
If you follow this link you should be able to download the manual for this unit and that may help you further
Regards
Gordon
Apr 17, 2011 | Carrier 30HXC096 Indoor Water-Cooled Screw...
Looking for a parts list/owners manual for an old carrier AC unit. Model #38 REO 36 300. Any idea?
Follow this link to the search page for the Unit need need literature on. If you want to change models (i.e. from the 38BR to the 38RE, both of which you list in your question), just enter the 1st 3-4 characters in the search box. this link is for the 38RE. Good luck!
http://www.commercial.carrier.com/commercial/hvac/technical_literature/1,3063,CLI1_CNT1_DIV12_ETI9039_MID4442_QRYY,00.html
May 27, 2010 | Carrier 38BRC036 Air Conditioner
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Carrier Air V roof mount with remote. Does not cool. On light blinks 5 times then repeats blink code. What does the 5 blink code mean?
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Mar 03, 2009 | Heating & Cooling
Where can i find a good service manual on line for a carrier 5h 40 open drive compressor
Dec 24, 2008 | Heating & Cooling
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
