Question about Innergie mCube Pro
My adaptor is flashing blue.
How do I get my M Cube Pro to have a steady blue light instead of flashing?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Usually in any type of laptop charger the flashing light is a blown fuse or resister only by taking the device apart and finding the blown part (maybe visible) and either replacing or just soldering over it will do, you could also try getting a bit of copper wire from old phone charger or speakers or even coax ariel and taping it across the part with insolation tape but that is deffo your problem and this is deffo your fix :) good luck
Posted on Oct 12, 2013
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
I have a hp6735s i got a new battery and it turned on for all of 2 mins then went of its bin charging for about 10 hrs and blinks half ornage half blue but wont come on at all .. the ac adapter voltage is...
The Genuine Battery for this laptop is:
(HP: HSTNN-IB51, 451086-361)
47WH 10.8 Volts
Adaptor sounds right also, though its not the volts that count ( give or take 0.5 volts each way) but the amps that matter, guess your charger will be a 3.25 or 3.65?Amp if its a genuine charger?
The actual problem could be down to a few things:
1.) Check the adaptor, see that the LED light on the adaptor is not flashing green, it should be steady. if in doubt, try a new adaptor or a borrowed one if possible. An adaptor that looks ok, may also fail under load.
2.) Check the DC jack port and see if the centre pin is loose, if it is, the DC jack will need replaced in the laptop.
3.) with a toothbrush or similar, clean the metal fins in the battery bay that the battery locks into, good contact here is important to the batteries ability to charge.
Jul 24, 2011 | HP Compaq 6735s Notebook
Flashing red & blue light; drive cannot be accessed.
Hi Caroline,
First off, 5 years is a normal time for a drive to fail.
From your description either the drive has failed or the circuitry in the external enclosure.
If the drive is simply a backup drive, toss it and buy a new one. If on the other hand you have data on the drive that you need to recover, try taking it to your local PC shop and have the techs there move the hard drive into a new enclosure. If it works you'll have access to your files.
Either way I highly suggest buying a new backup drive as this one either has failed or is likely to soon.
If the drive transplant doesn't work and you need access to the files on the failed drive, comment back with your location(Country, State, City) and I can refer you to an appropriate pro.
Hope this helps FixYa,
Chris
Mar 26, 2010 | Fantom Drives 120 GB Hard Drive
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
New phone need to connect with bluetooth
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 07, 2009 | Plantronics Voyager PRO Bluetooth Headset
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Flashing Temp indicator light, after 5 min on a cool morning
Its a Low Coolant indication. Fill the reservoir to at least the MIN level.
Jun 02, 2009 | 2002 Volkswagen Cabrio
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Innergie mCube Pro Logo
121 people viewed this question
Top Innergie Computers & Internet Experts
David Payne
David Payne
Are you an Innergie Computer and Internet Expert? Answer questions, earn points and help others
