How is it effective as in helping me solve equations
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What make and model calculator? What type(s) of equations?
Posted on May 09, 2013
How to solve quadratic equation on fx-83gt plus
It will help to read the manual of the calculator. As you can see from the screen capture below, the FX-83 GT PLUS ( which has more features than the FX-83 GT( does not have a solve mode or an Equation mode. So, you cannot solve equations on the calculator.
May 24, 2014 | Office Equipment & Supplies
How to solve quadratic equation in fx-100ms
See if it has an equation mode, and select quadratic equations. If it has a SOLVE feature, enter equation, provide a guess and solve.
Feb 26, 2013 | Casio Office Equipment & Supplies
I want to solve an complex equation on casio fx-570 ES Plus
Your scientific calculator is unable to solve complex equation with complex coefficients. You should try to solve by hand directly using the quadratic formula or by factoring the polynomial in z
failing that, another way would be to set z=x+iy, substitute this for z, carry out the algebra and try to separate real and imaginary parts. But your two equations will constitute a system of two quadratic equations. I am not aware of any general method to solve coupled nonlinear equations.
Good luck.
Dec 20, 2012 | Casio FX-115ES Scientific Calculator
What ia the sulution of 3y-6x=-3
To find the solution, first find the value of y for each equation.
Then substitue one equation into the other so that you only the x variable left.
Then just solve for x.
Once you have a value for x, then you can easily solve for y.
So for the first equation:
3y - 6x = -3
3y = 6x - 3
y = 2x - 1
Now for the second equation:
2y + 8x = 10
2y = -8x + 10
y = -4x + 5
Since both equations equal y, they also equal each other, therefore:
2x - 1 = -4x + 5
Now just solve for x:
2x + 4x = 5 + 1
6x = 6
x=1
Now substitute x=1 into either original equation:
y = 2x - 1
y = 2 (1) - 1
y = 2 - 1
y = 1
Therefore the solution is x=1 and y=1
Good luck, I hope that helps.
Joe.
Nov 09, 2011 | Texas Instruments TI-84 Plus Silver...
How to do equations the papers that come with it doesn't explain it very well. Is there someplace where I can get a better explaination?
You can solve equations two ways: The EQN computational mode or the SOLVE application.
IN the EQN mode you can solve linear equations in one, two and three unknowns; the quadratic equation; and the cubic equation.
Enter the EQN mode by following the instructions on the following screen capture. Press 5:EQN
You have three types of equations.
Once you select the type of equations, a template is displayed where you enter the relevant coefficients.
Under each label (a, b, etc. ) enter a coefficient and press ENTER to move to the next. With a cubic equation, or a linear equation in 3 unknowns, you have to use the Right arrow to display the cells where you enter the value of d.
After you input all necessary coefficients press the = sign to get the solution.
To use the SOLVE feature, see the screen capture that follows. It comes from the Casio manual.
Good luck
Jun 24, 2011 | Casio FX-115ES Scientific Calculator
How to input cos x=0.75?
I assume that if you want to input the equation it is with the intent to solve it. If that be the case then what follows will help you input and solve any equation (linear, quadratic, trig, etc.)
Make sure the calculator angle unit is the same as your problem requires (degree, radian, grad). Here are some screen capture to help you. Change the equation to yours. 21c8779.jpg4b6c1ea.jpg
To enter the equation in screen above, use the right arrow.
You have to enter an initial guess on line X=, a default value may be supplied by calculator: It depends on last value stored in X. Once a value is entered press the F6 key to SOLV
Press F1: Rept if you want to solve another equation.
Nov 13, 2010 | Casio FX-9860G Graphic Calculator
Want to solve quadratic equations on my casio 3650p super fx
In your manual, Appendix Program Library, (Page A1) you have the listing of the problem to solve the quadratic equation. Type it in your calculator and execute it.
Hope it helps.
Aug 13, 2009 | Casio FX-9750GPlus Calculator
Solving systems of equations by elimination
Hi joanmae jmeh;
You can add these equations just like you would numbers
3x + 2y = 7
5x - 2y = 1
8x =8
x=1
Now plug x = 1 back into either equation and you can solve for y
Y = 2
When you add the 2 equations together the +2y and the -2y cancel
out
Hope this helps Loringh Please leave a rating for me Thks
Dec 01, 2008 | Bagatrix Algebra Solved! 2005 (105101) for...
Solve comlex equation
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
b4c488c.jpg Hope it helps.
Oct 31, 2008 | Casio FX-9860G Graphic Calculator
Help
If I'm not misunderstanding you, this isn't an equation you need a calculator for, it's basic algebra. Factor out the z from the right side and divide x by the remaining binomial. That's as far as you can go with an equation like this unless you have specific values for these variables, unless this is a question from college Cal 3-4, which I have not yet completed.
Sep 16, 2008 | Texas Instruments TI-89 Calculator
13 people viewed this question
jasbo
jasbo
