Question about Garden
Bolens manuals how to replace broken pull start
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Bolens push mower Briggs mower when pulling fo start and running pushes gas out of the ventholes of the fuel cap.
I think that you have a defective gas tank lid that is not venting properly which could pressurize your system and cause problems. Invest in a replacement and hopefully this will solve your problem. The cap has a small breather vent cover [it sort of looks like a small mushroom], this allows air to enter the tank, but keeps air/fuel from going out of the cap. Some mowers use a pressurized system, and I am not sure if Bolens is one of them.
Sep 21, 2013 | Garden
My Bolens 500 Series lawn mower is hard to start
if it is a pull motor then you have to put some oil in the end of the chain(string) near the motor then it will pull smoothly.
Sep 29, 2012 | OEM Replacement Parts Garden
How do I put a genuine factory parts deck drive belt O.E. 954-04062/754-04062 on 38"Bolen's lawn tractor model#13AM762F765
To start with, the easiest way is to remove the mowing deck from the tractor. It will really be tough if you don't or can't. You may need an owners manual to guide you through all the steps.
1. Remove the cutting deck from the tractor 2. Work the old belt off (if not broken) the mandrel pulleys and idler pulleys 3. Pull the belt away to reinstall a new one 1. Work the new belt around both the mandrel pulleys 2. Make sure the belt is in all the pulley grooves and inside all the belt guides 3. Now you have to reinstall the mowing deck. Here are some diagrams that should help you.
http://www.ereplacementparts.com/bolens-13am762f765-2005-lawn-tractor-parts-c-27272_27390_27402.html
Apr 19, 2011 | Garden
Fuel pipe broken
If it is just the fuel line go to any lawn mower repair shop and get a piece of bulk fuel line and replace it. If it is the fuel primer bulb and tube here is the manual
http://www.oscar-wilson.com/MANUALS/BOLENS/21B-121R765.PDF
See item 8
Sep 28, 2009 | Ryobi Cultivator
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
I have a bolens 36" ride on lawn mower 12 hp and i have have broken the cutting deck bels and i have bought the reokacement but i cannot work out how it goes on correctly the model number for the bolens is...
Hello can I please get your model number please. To find out where it is please refer to the link below:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151&LeftNav=true#
Then click on the "click here" to find out how to find it out.
Dec 01, 2008 | Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
