Problems carrier edge thermostat
I just had a new carrier heat pump system installed with a Carrier performance - non-programmable EDGE thermostat (TTNRH01A). I am having a problem with the thermostat. During the day when in the cooling mode the thermostat and system works fine. At night, when the temperature drops, the AC cuts off as it should but the temperature (Actual Temp) that the Thermostat displays never changes. It continues to display the set temperature even if the ambient temperature drops several degrees. My HVAC installer replaced the original Thermostat, but the new one does the same thing. Has anyone else had this problem and/or know what the problem is?
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Feb 27, 2009 | Carrier Heating & Cooling
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Carrier Performance Edge Programmable Thermostat
Are you a qualified refridgerator mechanic with an eletrical liscence? If not get someone who is because doing it yourself will not only void the warranty of the unit but will also void your house and contense insurance in the event of a fire.
Feb 13, 2008 | Heating & Cooling
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
