Zanussi ZWF1632W my washer keeps stopping mid cycle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Potinchmeter
Posted on May 14, 2013
natengel
  • 19 Answers
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
Posted on Oct 31, 2007
  • 3 Answers
SOURCE: Washer stops mid cycle
I had this same problem, it was the lid switch on the left side of the lid that was causing the problem. It seems to be designed to stop the washer if the load becomes too unbalanced. I ended up taking off the control panel and looking at the switch. The problem switch is a two part brass metal switch, the two parts are connected by a spring. It appears that the join at the spring started to work itself loose easier as I used the washer more. I ended up putting a twist tie around this join (through the square hole and around the part that descends vertically into the washer), and tightening it up well so that the two brass parts would stay connected and not release apart so easily. It seems to have worked well, I haven't had this problem re-appear at all.
The one thing that I am careful of now is the load balance of my washer. Since my 'repair' in effect bypassed the load imbalance mechanism of the washer, I am more careful of how much I put into the washer.
Other than this hiccup, I'm quite happy with this little washer and how well it has performed. Great value for the money!
Posted on Dec 22, 2007
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 106 Answers
SOURCE: washing machine keeps stopping mid wash and coming
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Posted on Feb 27, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Does zanussi aquacycle zwf1632w have a quick wash cycle
yes your that model has a quick wash its about a 45 min wash have you looked in your manual it will tell you how
Nov 17, 2011 | Washing Machines
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Washer won`t rinse or spin model zanussi zwf1632w
Lid switch might be broken or transmission might be jammed.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Drum stopped turning mid cycle, think something is stuck, have opened up backbut cant access drum
If there is no removeable cover on washer, then you have to remove therear half of the cabinet to gain access to the drum etc.
Jan 17, 2010 | Zanussi ZWF1430W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
