Question about Kenmore Refrigerators
Kenmore coldspot refrigerator repair
Food freezing on refrigerator side
  • Kenmore Master
  • 4,655 Answers
kenmore coldspot refrigerator repair - 20b285e5-2f39-4d20-a743-32f4ef00196e.jpgKenmore uses a model number like this example=> 321.2468901 and can be found around the fresh food section door frame. Let me know that number so I can look over the parts so I can help you solve this, Thanks Sea Breeze
Posted on May 10, 2013
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I have a Kennmore side by side model # 522521 it all of a sudden the freezer part stopped freezing, the motor is still running. The Refrigerator part stopped cooling just after that.
Posted on Oct 19, 2008
  • 1122 Answers
SOURCE: Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Posted on Dec 16, 2008
rpbuice
  • 161 Answers
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Posted on Feb 11, 2009
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
SolutionGuy
  • 331 Answers
SOURCE: I have a Kenmore Coldspot Model 106.59502992 that
Hi Danda,
About 98% of the time on a Whirlpool built Kenmore such as yours the problem with automatic defrosting is the "defrost timer". It's super easy to repair. You can get one from Sears, a local appliance parts retailer or just about anywhere online (just plug this part number---> 482493 <--- into a search engine and price shop)
Here's a diagram I made. It details the repair. Number 4 says "ADC", don't worry. There are two types of defrost timers one is an ADC and another is yours. They both follow the same repair procedure, OK?
Here's a full size diagram of your machine. You'll see that there is no difference other than the type of defrost timer.
NOTE---> UNPLUG YOUR FRIDGE BEFORE DOING THIS REPAIR!!! Otherwise, you'll look like this permanently...
There ya go, Danda! Remember to rate this solution as "FixYa" WillYa?
SG
Posted on Apr 22, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Refridge side is freezing. freezing food .
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 04, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Ge electra series side by side refrigerator keeps freezing food in my refrigator
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZE FOOD ON REFRIGERATOR SIDE AND NO WATER ON DISPENSER, MIGHT BE FROZEN ON FILTER
heatman101
Feb 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My SxS model 25 GE fridge is freezing food on the fridge side. I have turned it down to 1 and it still freezes the food.Also my water dispenser does not work. Can the 2 problems be related? How can these...
heatman101
Jan 05, 2011 | GE GSS25LGM Side by Side Refrigerator
Suddenly the refrigerator is freezing everything we have not changed the settings we tried to even turn down and is still freezing the food.Help!
heatman101
Jan 04, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Freezes food in refrigerator side
the problem should be with the temerature controller in the refrigerator. ask for the nearest technicain to come and fix it.
May 29, 2009 | Electrolux Refrigerators
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerators Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
