How will i know when my sharp ar122e toner is faulty
    New Friend:
  • 32 Answers
In my opinion all toners are alike, the characteristic of a faulty toner can be dirty spots of toner on the print. This can happen even on a new toner no matter the brand even if its oem or not. Remember to shake it side way several times, make sure its clean and not licking. Then when you install it at the drum remember to clean the wires several times, usually the green tab at the left.
Posted on May 10, 2013
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
My copier is SHARP AR-M237 will be to change the toner and I get an error. Code F2-04. What can I do in this case, please help.
your toner should be AR-270NT or AR-310NT. Try cleaning off the brass colored contacts in the plug on the back of the toner cartridge. The toner may also be faulty (try another) Also the contacts inside the copier may need to be cleaned by your copier technician.
Nov 17, 2009 | Sharp AR-M237 Copier
Error code E000020-0000 in cannon ir5000/6000
Main cause: The machine is not receiving toner properly because 1)The hopper connector is left disconnected. 2) The hopper motor (M9/M10) is faulty.3) The toner sensor (TS1/TS2) is faulty. 4) The DC controller PCB is faulty.
If you recently added toner, recheck that area.
Basically the copier is trying to add toner and is not getting it.
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
What does it mean 2 and f flashing on my copier
An F2 code means you've either got the incorrect toner cartridge inserted into the machine or toner cartridge is faulty (there's a chip on the toner cartridge that identifies it to the copier). Please make sure what you've loaded is AR-016TD.
Sep 02, 2009 | Sharp Office Equipment & Supplies
Changing toner getting U2 40 code
The cartridge is faulty, in most cases not a genuine cartridge. If the copier works with the old one that means the "new" cartridge in defective.
If you brought a original Sharp cartridge you should return that and ask for a new one.
Jul 25, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
14 people viewed this question
k24674
jasbo
jasbo
