Question about Kitchen Ranges
Kitchenaide Superba oven problem
Replaced the control panel because it went blank. Thats ok now but now the oven turns off while in use and comes up with an error message F1E2. If I bang on the control panel with my hand sometimes that works which makes me wonder if something is loose. Even replaced the heat element but still comes up with the error code when I'm using the oven. Sometimes the oven will work for an hour sometimes less. Never know when it will turn off. What else can we try other than buying a new stove. Love this stove and hate to look for another So far this problem has cost almost $600.
  • 15 Answers
SOURCE: oven touchpad doesn't work
sometimes it may just be a build up grease and dirt on the pad over a period of time.try taking it apart as much as possible and cleaning it with some type of spirits and the clean with some eucalyptus oil as both of these have capabilities of breaking down oils and fat.
Posted on Jul 19, 2007
revamos
  • 16 Answers
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Posted on Apr 21, 2008
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
  • 147 Answers
SOURCE: Display goes blank, no heat, no oven
This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
Posted on Nov 03, 2008
Kitchenaide oven error code control panel went blank. oven light still worked. 3 days later it went back on. it is still under warrenty what should be replaced
If it is still under warranty, let the "professionals" figure out what needs to be replaced. If you do it, you will void the warranty.
Oct 27, 2017 | Ovens
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Kitchenaide superba oven door handle
screw them back in, or get a little bit larger screws because those were not the ones that should have been in it to start with
Jun 05, 2012 | KitchenAid KESC307 Electric Kitchen Range
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Superba KGT607HBS oven stopped working
The flame went out.  Move the oven control back to where it sounds like it is lighting.  After it clicks a few times and sounds like you have a flame set your temperature again.
Nov 27, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
