Question about KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaide Superba Gas stove control panel
Replaced the control panel because it went blank. Thats ok now but now the oven turns off while in use and comes up with an error message F1E2. If I bang on the control panel with my hand sometimes that works which makes me wonder if something is loose. Even replaced the heat element but still comes up with the error code when I'm using the oven. Sometimes the oven will work for an hour sometimes less. Never know when it will turn off. What else can we try other than buying a new stove. Love this stove and hate to look for another.
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Posted on Jul 02, 2009
SOURCE: My kitchenaid superba has the control lock stuck
the control lock shows up on my stove how do i get it off.
Posted on Aug 17, 2009
pride applia
  • 232 Answers
SOURCE: Largest element heat remains high in every position
you need a new switch no dought
Posted on Dec 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: KitchenAid KGRT607HWH6 temperture, light, error code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Kitchenaide oven error code control panel went blank. oven light still worked. 3 days later it went back on. it is still under warrenty what should be replaced
If it is still under warranty, let the "professionals" figure out what needs to be replaced. If you do it, you will void the warranty.
Oct 27, 2017 | Ovens
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
