Question about Fat extraction holder Kitchen Hood
Smeg ksed62x Lights and fan have failed. Wired to mains. Is there an internal fuse? Thanks
If fan element fails on a Smeg dual fuel cooker will it stop cooker from turning on? The clock works but no other lights. Cooker not set to Auto. Is there a fuse or other power cut off? Checked topThermal...
If there are other touch switches that are not responding, then the fan failure might not be your problem. If might just be the electronic control board itself. Before you speak of 'fan failure' check the board to see it it is responsive.
The clock will always work even with fan failure.
Check all the wires and harnesses to the control board...unplug and replug them back in.
What is a 'fan element?'
Oct 23, 2013 | Smeg Kitchen Ranges
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Sep 10, 2009 | Smeg Ovens
I have a Smeg A1 Oven which has lost it's power
The fuse is located behind the rear panel of the cooker. Depending what model this is, it may be an electronic card causing the problem?
Apr 02, 2009 | Smeg A1A.1 Gas Kitchen Range
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Replacing fan element in Smeg SUK61MFX
what colour cables go to the 2 conectors on the fan element of a smeg suk61 mfx cooker
Feb 16, 2008 | Smeg SUK61MFX Gas Kitchen Range
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Fat extraction holder Kitchen Hood Logo
Top Fat Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Fat Kitchen Range Expert? Answer questions, earn points and help others
