Question about Sony VAIO VPCCW21FXW Notebook
Key board problem
'hash'and 'at the rate of' keys(numeric 2 and 3 keys)are not printing after upgrading to Windows 8 from Windows 7
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Go to control panel
Window vista Click on CLASSIC VIEW
window 7 Click on address bar and select ALL CONTROL PANEL ITEMS
click on REGION AND LANGUAGE
Select KEYBOARDS AND LANGUAGES
Click on CHANGE KEYBOARDS
Click on ADD
Now select which region that the laptop and you belong from
Click on left plus sign of Keyboard and select any below empty box
click on ok
Now in Default input language down select the region keyboard that you have choosen
click on ok
click on ok
Posted on May 12, 2013
  • Krishna Mohan Raju May 13, 2013
    Thank you Mr. David. It worked
Hi, am ganesh functions keys
If those are the only keys on the key board that are not responding, I would try to
1. boot in safe mode and check response. If you have other keys on the laptop that are not working,
2. I would boot operating system from a flash drive and check
and if both still are not working for you
3.try an external key board
Last replace the key board
Hope this helps
Sep 05, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Unable to print? how do i print to file?
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jul 22, 2011 | Computers & Internet
Ink system failed unable to print
May 25, 2011 | Office Equipment & Supplies
Unable to print error 36. Can't copy anything
Resetting purge counter:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Office Equipment & Supplies
Keypad hash key will not work
if no other keys are affected. then it is the numeric keypad assembly.
weblink below(the upgrade section):
http://cnn.cn/shop/advanced_search_result.php?keywords=k800
or on this weblink:-
http://www.telement.co.uk/selcds.asp
part number ROA1281764
hope this helps.
g
Oct 08, 2009 | Sony Ericsson K800i Cellular Phone
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Sony VAIO VPCCW21FXW Notebook Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
