Question about Ovens
UNIVA 718 -
There are 8 Univa 718 stoves in ou Consumer Studie Class. Some of them needs new thermostats and other elements. We do not know where we can find parts and did not have manuals of the stoves. Can you provide us with a manual and tell u where we can find spare parts. They must be 40 years old.
2 Suggested Answers
SOURCE: need wiring diagram univa stove /oven model ph14s
Were do I get the skimatics for a stoves wiring as I have to put the regulater back to geather as old one fell apart.
Posted on Oct 28, 2010
Elements does not heat up but the oven slowly does... The numbers go back to100 then slowly goes up but does not get hot
how old is this stove
slow stove means an expensive service
first
faulty thermostat
replace the elements
oven door seal
second
the dials
May 29, 2016 | Ovens
I need a wiring diagram for a univa oven 182/UC/B
try the MANUFACTURER'S website . we do not have it here
Mar 31, 2016 | Ovens
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
The fan is working in the oven but not heating up
Be good to know if electric or gas but most likely electric. Either the element has opened,(gone bad) or the thermostat has goon bad. Very unlikely that the temperature rheostat (knob to set temperature on stove) has gone bad. But check the elements first.
Jan 17, 2011 | Ovens
I have a whirlpool gold accubake # GJP84802, when I was using the broil on 500 F, it tripped the breaker. When I turned it back on, the lower element is not producing heat (top working). Is there a fuse...
It sounds like your heater element is burnt out. Get a volt meter. Unplug the stove. take off the back, disconnect one of the wires connected to the element and test it. It should read approximately 11 ohms if good. If a high or no reading, the element needs replacing.
If the element is bad it is easy to change. Just slide out the stove from the wall. Take off the rear cover and just unplug or unscrew the leads from that element and replace. First make sure you unplug the stove it's self from the wall. it does have 220 volt and will hurt you. However if the new element too doesn’t work then you need to check the selector knob (COOK/BROIL) and the thermostat for the oven. To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
But above all there can be a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Let us know if you want something more else accept the suggestion.
Thank You for contacting Fixya.com
Jun 18, 2010 | Ovens
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Need wiring diagram univa stove /oven model ph14s
Jan 22, 2010 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
