Question about GE DBXR463EDWW Electric Dryer
Ge dryer dde7100
Humidistat
I have an AprilAire 550A with bad humidistat. Can't find replacement. Got a 550 but wiring not right. Not sure what to do!
I believe they just updated model number descriptions. The basic design of that humidifier hasn't changed much over the years. I would go to their website and look for the one that is simiar to your model and get the humidistat for it. They are pretty basic devices as far as what the humidistats do. 24v power and common
Feb 23, 2013 | Aprilaire Humidifiers
I have a Honeywell House humidifier HE 225A-1006.
In order of probability:
1) (incorrect wiring) Make sure that humidistat is in SERIES wired with the furnace.
2) (shorted wires) Check that two wires to humidistat are not touching...use your glasses if you need them!
3) (bad humidistat) disconnect the humidistat and put an ohmmeter accoss the two terminals when it is turned on you should read 0 ohms, and when off it should read infinate ohms, if not pass both these tests, you need new humidistat.
That is it, there are no other possibilites!
Oct 12, 2009 | Honeywell HE220A1019 Whole House...
Dryer runs hot and will not shut down automatically
there is a thermostat or what we would say a high temp switch near the heating element to keep it from getting to hot , the internal parts of the vent must be cleaned as well, cleaning the vent and the screen is not always good enough. Ive had to completely take the dryer apart and pull all pipes apart all the way to the lint screen to fix this problem.
Jul 23, 2009 | Dryers
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Why do I hear some people say not to trust a humidistat?
Because they don't trust humidistats. Because they don't know what to expect a humidistat to do, or how accurate to expect the humidistat to be. Or, perhaps because they actually had experience with a humidistat that wasn't working properly.
Jul 23, 2008 | Heating & Cooling
GE AHH40LH DEHUMIDIFIER
Either the humidistat is bad and not letting the unit cycle off, there isn't enough humidity in the air, or the condensor coils are too dirty.
Nov 14, 2007 | GE AHG40LJ Dehumidifier
Does Not Collect Water
sounds like a faulty humidistat, but may also be nearly out of freon. I have a GE unit that is also a portable air conditioner...works great for 5 years now...
Jul 09, 2007 | LG DH404E Dehumidifier
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
GE DBXR463EDWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
