Question about Brother P-touch® PT-2700 Label Printer
Encoder error solutin - Brother P-touch® PT-2700 Label Printer
Magnetic encoding error
try to update firmware. check if driver can read the encoder from a used card.
Feb 19, 2014 | Zebra Office Equipment & Supplies
Tip
PHP DOMDocument->load() encoding error
Where there are funky characters in the XML file,DOMDocument->load complained about them, saying that they weren’t UTF-8, and to specify the encoding.
For example,Warning: DOMDocument::loadXML(): Input is not proper UTF-8, indicate encoding !
Bytes: 0xE4 0x3C 0x2F 0x66 in Entity, line: 1 in test.php on line 6
with doc->recover=false(default) : failed
Solution:
on May 16, 2010 | Computers & Internet
Riso error CODE p20-437
P20-437 Paper-ejection encoder sensor status does not change within 10 milliseconds after the paper-ejection motor is activated.
This error occurs when the encoder disc either breaks or slips off the motor. The encoder disc is either a plastic or metal gear toothed disc.
Sep 23, 2013 | Office Equipment & Supplies
CR motor encoder check error
CR Motor is DC motor with brushes for driving the carriage. Controlled by CR linear encoder and CR linear encoder sensor. So, check the encoder. It may be dirty or some lines missing. If the encoder OK, other possibility is the sensor.
Jan 28, 2013 | Epson Stylus Pro 7600 InkJet Printer
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Hardware error 0502 from A dell 940
Here is how to fix error 502.
Rick
» Reposition the Encoder Strip on the A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Jun 14, 2011 | Dell A940 All-In-One InkJet Printer
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Solucion para error 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board
May 27, 2010 | Canon Office Equipment & Supplies
Any one help my brother display error 48, init unable 48, what are the things that i have to do?
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you lift the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Jan 21, 2010 | Brother DCP 165C Compact Color Inkjet...
ERROR HADWARE 03130031-2F26
this error code pops up again or is replaced with the f13 message...solution..wheel the printer to your companies parking lot and take a fire axe to it on your lunch break and never buy a canon product again.
Jul 09, 2009 | Canon imagePROGRAF IPF710 Printer
Brother P-touch® PT-2700 Label Printer Logo
44 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
