Question about AKG K 480 Noise Cancelling On-ear Mini Headphones
Akg repair k 480 nc
Side with the connector not working
2 Suggested Answers
Xome
  • 79 Answers
SOURCE: I have a AKG K 480 NC headphones. There is a loose
The wires must have been damaged so remove the casing and place extra lead on connected points and the wires well.
Think this is helpful !
Posted on Aug 12, 2010
Akg repair
spray it with contact cleaner or wd40 and work it back and forth a few times
Jul 26, 2014 | AKG SolidTube Professional Microphone
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
I got a skullcandy TI 1 year ago, and since two days the sound comes out normally, or without the left side, depending on the position of the wire connecting the MP3 to the skullcandy. It's very sensitive,...
What typically happens is that the base of the wire gets stressed from wrapping the cord around your media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more careful with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Audio Players & Recorders
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
How to disassemble it to fix connector
On the side near the connector you find a small screw.
Just loosin it and you can pull the connector out of the housing.
Here you can find a service manual.
http://www.akg.com/mediendatenbank2/psfile/datei/39/C1000s4055d1ee2167f.pdf
Regards,
Gerard
Jan 16, 2010 | AKG C1000S Professional Microphone
I have an AKG C 568 EB and think I have a faulty connector on it. I have checked inside and cannot see anything loose, but the plug needs to be jiggled to make it work properly when it is inserted. Is the...
Well, if it's not the cord it has to be the mic plug and it sounds to me like it's loose even thought you can't see that it is. If I could get my hands on it, I could fix it -- but that won't likely happen -- so I'd say it's off to the repair shop.
Apr 28, 2009 | AKG Audio Players & Recorders
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
AKG K 480 Noise Cancelling On-ear Mini Headphones Logo
47 people viewed this question
Top AKG Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you an AKG Radio Communication Expert? Answer questions, earn points and help others
