Question about Neff Dryers
Neff r4381x1eu switched on, everything lit up. when you press start nothing happens. Please help. Alison.
3 Suggested Answers
applianceboy
  • 77 Answers
SOURCE: Neff Tumbledryer
dont know much about commercial units but if it was a residential unit i would first check the door switch. in res machines it cuts the power to the motor only so every thing works but it wont go.
Posted on Nov 08, 2008
heatman101
  • 43501 Answers
SOURCE: power is on but nothing is happening when i push
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 17, 2010
Mirowave wont start
I assume from your description that you can set power and time but nothing kicks in when you press start?? This could be a control panel fault but may be a problem with the door lock/switches. Check that the spring on the door hooks is ok, just lift it up and check it returns to down position by itself. If the microswitches do not make properly when the door is closed the m/w will not start because it assumes the door is open. A microwave (even when switched off) can be storing a high voltage so unless you are trained I would suggest you get an expert to take a look. BSH is Neff service division 0844 872 8999, they offer a one off repair plan, which covers your first repair and then any further repairs for a year. You can pay monthly by DD to spread the cost. (This may be age related so as yours m/w is nearly 10years old, it may not be eligible).
Hope this helps.
Mar 21, 2013 | Neff Microwave Ovens
My Neff integrated dishwasher has been used 5 times and now no power lights coming on and nothing happening. This is a new build and purchase is out of warranty as we have just moved in 2 years on. The...
the only thing i can say is that you should ring up the company and tell them what is happening and ask them can they tell you what to do
Sep 03, 2012 | Dishwashers
Bluetooth indicator is not lit despite I switch the wireless ON
Confirm the phone number where you would like Verizon to call you. We will call you momentarily to connect you to our automated system. You can also call us at 1 (800) VERIZON (1-800-204-4427).
Apr 13, 2017 | Dell Latitude D830 Notebook
Problem: No display everything running including cpu fan, pci card everything. No error sound. Anyone please help. its a x58 chipset. I also checked that the motherboard getting hanged. like after running...
You will remove the CMOS battery and wait for 5 minutes .
Hope it will solve.
If the problem is same please change or clean the RAM with eraser and install it again.
If the problem is same please ,
http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new.
Hope this helps.
Jan 10, 2011 | ASUS P6T Deluxe Motherboard
On boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
Oct 10, 2009 | Dell Vostro 1500 Notebook
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
The on switch will not turn dryer on
Hi everyone. I would be grateful for any help. I have a Miele Novotronic T220 tumble dryer. I cannot switch the thing on! The finish lamp is lit continually, and I cannot start another drying cycle.
I have unplugged the machine and pressed the start button again, but nothing happens.
Has anyone got any ideas for a technophobe.
Aug 10, 2008 | Dryers
Neff Tumbledryer
Aug 02, 2008 | Neff R4381 Electric Commercial Dryer
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Dryers Logo
46 people viewed this question
Top Neff Dryers Experts
gbob59
ray gallant
Nicholas Tipples
Nicholas Tipples
Level 1 Expert
Are you a Neff Dryer Expert? Answer questions, earn points and help others
