Question about LG Home Theatre System HT302SD
Eax32631003 circuit diagram
Can I get this board, this power unit has several problems, diodes short cut(D951,D952), rectifier bridge(BD 901) short cut, IC902 short cut, zener diode 33V (ZD902)short cut
  • 159 Answers
SOURCE: I have a DVD player LG LH-T9654S, it was broken by
Hi, as you've lost the original parts I suspect finding their numbers may be next to impossible but not to worry. There are several " STAGES " for some power supplys-one stage will drive the final amplifier circuits, while another drives the dvd portion and another for the fluorescent display. My advice is to use a part number from another stage of the power supply ( make sure the diode looks the same ) and if that feels wrong just order a diode that has at least a 100 volt rating for 3 amps and that should do the trick. I hope this was of some help, write back & let us know if we helped or can be of further assistance, Thanks for asking FixYa, and good luck-Prodzilla
Posted on Apr 14, 2011
SD Tech
  • 14553 Answers
SOURCE: LG 32lh200 power supply failure common problem
You might try to follow the diode back to the source and read voltage to know the value of the diode and also look on the diode for generic number--short of that Google the model number with "parts" as it might be cheaper to replace the board than try to fix it by guessing values.
Posted on Aug 27, 2012
gopakumarg43
  • 75283 Answers
SOURCE: LG 47LB5DF bad part
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Try it, and see whether it help you or not.
Posted on Feb 26, 2014
  • 112 Answers
SOURCE: Where to get clear diagram of magnetron circuitry with capacitor and diode circuits shown ?
Below is a common diagram for LG Microwave "High Side" components.
The component below the Monitor Interlock Switch is the Transformer. So, on the High Side of the transformer, you can see all the components.
Can you give me the model number of the unit that you are wanting information?
Posted on Apr 10, 2015
gopakumarg43
  • 75283 Answers
SOURCE: The value of zd442 zener diode which r used in afc circuits of LG flatron crt tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Oct 16, 2015
I have an LG 55lm4700 that has no power led and no picture, wondering what might be the issue.
it sounds like a blown capacitor in the unit somewhere.
here are some tools you are going to have to have: ohm meter,oscilloscope, signal generator, soldering equipment,
grounding equipment, diagrams, schematics, test points, layout of circuits,
Sep 18, 2015 | LG 55-Inch LED LCD TV - 55LM4700 Cinema 3D...
In onida tv d2498 and fuse in power supply gone on connecting ac.Without main board installing please help
If it's not the main board that's causing the fuse to blow then you have a short circuit somewhere in the power supply. Check things like the electrolytic capacitors. The ones that look like little cans. They should all have flat tops. If any are bulging out at the top they will need replacing. Also check the bridge rectifier which is a black component usually standing up on the board with four legs. If there is no bridge rectifier there will be 4 rectifier diodes together. They are black cylindrical items with a sliver band on one end and a lead out of each end. They are usually located near to where the mains lead enters the power board. Other things to check are power transistors, they are usually 3 legged, (sometimes 2 legs if they are used as a diode) black items with their case fixed to a heat sink (aluminium block.)
Dec 15, 2014 | Televison & Video
Fuses keep blowing for my flat screen tv
Short circuited component/s at its main power regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | LG 42LC2D 42 in. LCD HDTV
Power supply fault [d212 short]
sounds like a bridge rectifier diode has shorted replace the bridge or make your own use 4 1000 piv diodes. can be purchased at radio shack. be sure to connect the diodes annode to cathode when making the bridge. also when a component shorts it generally opens the next component in series.in youre case i would definatley check the filter caps.sometimes if overloaded they will actually be swelled otherwise you will have to take them out of the circuit and read them with a cap checker on a quality multimeter. if bad be sure to mind polarity when replacing! electrolytic caps have a positive and neg. leg the board will be marked
May 29, 2011 | Sony DVP-NS51P DVD Player
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Dead Set after power surge
Check the power supply transformer primary driver transistor and the associated components (some diodes and capacitors, resistors, an optocoupler maybe) and the rectifier diodes (or a bridge) and capacitors at the transformer secondary, what you are looking for is a short circuit, however, the short may as well be in another section of the circuit board (a shorted component may sometimes have signs of damage caused by heat, but this is not a rule).
Hope you can find out what it is...
regards
Triarcuate
Oct 01, 2009 | Televison & Video
Same Problem, diodes fell out of bridge rectifier assembly
pulling to many amps,diodes could not handle amps so they failed.unit should have kicked its breaker before the diodes burned out.most units have their own breaker to protect the system.I would replace the control board first see how unit reacts,probly fine,if not the you go to next step.
Jun 27, 2009 | Coleman Powermate Premium Plus 6250W...
LG Home Theatre System HT302SD Logo
155 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
