What is the difference between timer ver. 5WK51316 13 & 5WK51316 14, Siemens Washing machine
BIKER T
  • 909 Answers
SOURCE: no power?
Timer is normally 2%of the problem. Usually if nothing happens at all, one would check incomming power, then door latch and or limit switch, then once switched off, inspect in control panel for blown fuse. It gets a little more technical after that as wiring sometimes runs through solonoid valves and motor windings to complete the circuit.
Posted on Jan 28, 2009
  • 154 Answers
SOURCE: Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Posted on Jun 22, 2010
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
FitzOriginal
  • 842 Answers
SOURCE: I am staying at a
Detergent in Left compartment for a normal wash, left AND centre if you are doing a long wash with a prewash. The conditioner goes in the little compartment (Probably has a lift off cover (which you don't need to worry about)
Posted on Jul 18, 2011
Testimonial: "Great advice and very quick to respond. Thank you very much!"
  • 6277 Answers
SOURCE: siemens washing machine feature "speedperfect
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing, or supporting, any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 05, 2011
Our Siemens washer stopped spinning We have renewed brushes goes round now. But only turns one way then the other for one revolution We have tried different cycles but all the same is it the programer
First thing I would check if that timer which you are calling the programmer. If the programmer is not displaying an error code you properly have a bad timer given what your saying
Dec 19, 2015 | Siemens Washing Machines
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Siemens watching machine wash & dry3120 timer not on and not taking water
Possible failure of the program timer unit as the controller is not ttriggering or powering up to activate the inlet.
you will need to remove the panel and open to observe the voltage to the controller to confirm further.
Oct 28, 2010 | Washing Machines
Hi How do I deactivate child lock on Siemens S 14 79 ?
On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds.
Oct 08, 2010 | Siemens WIQ1433 Front Load Washer
Siemens waching machine is on child lock how do I unlock it?
Select the mode in which the machine was running. And then press timer (Clock symbol) for 5 or more 10 sec. The lock will be removed
Jul 05, 2010 | Siemens WFXD8400UC Front Load Washer
Reset childproof lock siemens washerWM16S760DN
Set it to the last programme you had it on then press and hold the timer button for about 5 seconds.
Feb 06, 2010 | Siemens Washing Machines
SIEMENS WM1000 model timer to be connected.Kindly provide
i have a Siemens washing machine there is washing problem in washing ,some noise r generate like as chunk and wash cycle is not run proper and all function is work properly (darpan jain 9827622024)
Jan 25, 2010 | Siemens Washing Machines
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
Oct 03, 2008 | GE WCCB1030 Top Load Washer
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
