little risky you can try this its your own risk give the hot air of hairdresser dryer machine with lot of care. if problem not solved this is faulty lights rods controller ic some time by jumpering on side light rod problem solved but only expert can jumper of lights rod switching ic. Not easy at home repair. best way contect to expert repairing lab. for more about that topic visit this link Phonetolls
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
without a standby error code or maintenance mode fault detection code, it's hard to say.
if you are looking for possibilities, then start with targeting the Ysus board as a possible culprit along with the Zboard buffers. the band would lead me to think buffers are having issues.
its usually happen at k850i.the problem actually from display light on lcd are not lighting. if you have experience in phone you can make a jumper wire to reconnect light line between lcd and PCB(engine).but usually the fastest way are change the lcd phone.simple but need money.may it help.
