Question about Dryers
High pitched squeaking dryer
Really bad high pitched squeaking/ scraping noise from back of drum, is it fixable or do we have to buy a new one? It's not that old and isn't used regularly. Model is de45f56e thank you
    Novelist:
  • 185 Answers
Its just the bearing and it needs replaced. it will take about two hours to do and it will cost you about 30 dollars in parts. you can find many really goods vids on youtube that will show you how to do it and most parts manufactures now have directions on how to do it in the cluded when you buy the parts.
Posted on May 09, 2013
I heard the same noise too but not same answer sorry mine was the rear drum seal was worn out
Posted on Feb 03, 2014
  • 1 more comment
  • Shawn Paige
    Shawn Paige Feb 03, 2014
  • Shawn Paige
    I heard the same noise too but not same answer sorry mine was the rear drum seal was worn out pulling your hair out yet
  • Shawn Paige
Just corrected the exact same problem with my Samsung model DV409AEW/XXA dryer. Made exact same noise as your dryer on video. Turned out to be idler pulley that Mike Murphy mentions in his post. Didn't have to be replaced. Just lubricated with WD-40. Thanks for the help !!!
Chaplain Doug Sullivan
Posted on Dec 14, 2013
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: High-pitched squeaking during operation
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers may be in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 27, 2010
  • 384 Answers
SOURCE: High pitch squeak and removal of cloth support
try some felt from fabric store in same place
Posted on May 06, 2009
  • 61 Answers
SOURCE: High Pitched Squeak from Maytag Dryer
rpllers or tub bearing
Posted on Sep 29, 2009
heatman101
  • 43501 Answers
SOURCE: Scraping/high pitched noise in GE model DCVH515GFOWW.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfdyjsdf
Posted on Sep 29, 2010
Magic chef dryer making very loud noise as it turns, how to get the bottom off
No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Oct 13, 2014 | Dryers
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Oct 01, 2014 | Dryers
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
My dryer is making a high pitch squeaking noise during certain times of the drying cycle. Is it one of the wheels that turn the drum? Don
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
SQUEAKY DRUM!
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jun 07, 2010 | Fisher and Paykel DE08 Gas Dryer
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
My dryer had a high pitch squeak during operation for a while then suddenly seized and will no longer rotate.
there are really 3 items that could be causing your noise.
the most likely cause is you drive motor, it can get a worn bearing and make the noise, then when it becomes really bad, it just wont turn anymore.
also you could have a worn bearing in the idler pulley or drum support, but these usually wont stop the unit from running.
a new motor could cost about 150 bucks, idler 20 supports 25 each@2.
Mar 03, 2010 | Amana ALG643RB Gas Dryer
May 06, 2009 | Dryers
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
Dryer makes loud squeaking noise when spinning
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryers Logo
2,656 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
