My netbook screen is half black
After I used the infocus and turn my laptop of, my laptop is fine. but when I turn it on again, the screen is half black. and the other side of the screen is strange. i could scroll up, down, left and right my home screen. and sometimes, this happens when even I dont connect my laptop to the infocus. my laptop is acer aspire one D250-1GBw
    Sergeant:
  • 180 Answers
I think this screen must be changed by anew one .firstly tray to connect ur laptop to external monitor
Posted on May 19, 2013
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
Posted on Mar 12, 2009
  • 1684 Answers
SOURCE: Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 08, 2009
peachy20
  • 15 Answers
SOURCE: Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
Posted on Aug 07, 2009
  • 7 Answers
SOURCE: Acer Aspire One Netbook 8.9' Won't Boot Up !!!
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This is also known as crisis disk mode.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, with the flash drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS. After a while the button stops blinking, and the AA1 reboots shortly after. Wait patiently.
If it doesn't reboot by itself, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Posted on Jul 18, 2010
  • 13 Answers
SOURCE: acer aspire 3690 the right half of my screen is black/white/lines
It sounds to me like your screen has gone and needs to be replaced
Posted on Aug 03, 2010
Asus x58l half black screen
Damaged screen. Replace it.
Mar 17, 2014 | ASUS Computers & Internet
Tip
ACER ASPIRE ONE Netbook, black screen recovery
if you have got a black screen and it wont boot up.
use the recovery cd that comes with the netbook ,
put it in any pc that has got a cd or dvd drive,
and run the software , it will give you a choice of making a recovery usb
stick, you will need a usb stick with a minimum 2GB memory,
the program will take about 20 minutes to create the recovery usb stick,
when finished put it into any one of the usb ports on the netbook
and turn it on, again it will take about 20 minutes for the netbook recovery.
wrote this mainly for people that do not have an external cd / dvd drive that
they can use .
cheers steptoeson
on Dec 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Screen flickering after hibernate/sleep
in your keyboard system problem just unplug you key broad or outside keyboard use inside you dissable from device manager then check again
May 16, 2012 | Acer Aspire One D270 AOD270-1492 10.1-inch...
Black screen on advent verona netbook
A black screen on startup can be so many things! I have learned this lesson the hard way. Never turn off the computer when it is half way through the boot procedure. Even when it is taking forever, or having a major problem you must let it run through if possible. Interrupting it once may be ok, but twice or three times is a no no. After you have carelessly restarted and shutdown a few times the black screen may appear. But this time it may be beyond repair for the average computer user.
Check Below Link for Instructions:
http://tips4pc.com/articles/computer%20troubleshooting/how_to_repair_a_damaged_boot_sec.htm
Good Luck!!!
Jan 10, 2012 | Advent Netbook
I recently updated this netbook using the Windows 7 upgrade and went through the entire tech support call with Microsoft regarding accurate procedures to upgrade from xp to Windows 7. The netbook worked...
To let you know one FACT....
MS tech support is JUNK....
If you still want to use them it's you call.....
Solution
Get an external monitor and fix that to the monitor port (watch this video)
http://www.youtube.com/watch?v=J7MZ23T-NRg&feature=fvw
on the back or on side of the notebook serial port
if display on monitor is ok then there is some issue with you laptop display
if hardware is the issue
you need to aproach a tech shop to fix the issue
OS upgrades dont spoil hardwares....
Nov 29, 2010 | ASUS Eee 1008HA Netbook
Asus x83v screen is black and has vertical lines on half of it.
As the product is under a year old it should be covered under warranty. Get in touch with asus customer services before you let anyone attempt a repair as doing so may invalidate your warranty
Jul 27, 2009 | ASUS Eee 4G Notebook
Switched on notebook, and screen appears broken,
Hi there.
Yes you can have the screen replaced and you can do it yourself, however i would recommend that you send it for repair as these Eee PC's are difficult to disassemble and you have to know what your doing.
If you have any of the manufacturers warranty left on the netbook take advantage of that and send it to Asus for repair.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | ASUS Eee PC 901 Notebook
Compaq n610c screen turning off then back on after a halfhour
hello dear sir madam
how are you ...i wont to tell you that can you sell the laptop for me ...i am in nigeria and i wont laptop to use... so therefore if you like to sell you can mail me ...... this is my mail jamessmith0009@mail2world.com
Aug 14, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
