Tv looses pic and sound than comes back on
I have replaced thee lamp several times in the past. I have not done anything recently.The pic and sound turn off then comes back on by its self. WHY
  • 60 Answers
It sounds like it could be your main board. Over the years the board's connections could become loose or the board itself can be going bad. I would call an expert maybe someone from an online shop like rivervalleyelectronics.net can get you a board for cheap since alot of these older model TVs parts are not carried by the manufacturer.
Posted on May 17, 2013
ctf1800
  • 4402 Answers
SOURCE: Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Feb 06, 2008
  • 61 Answers
SOURCE: no pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Posted on Nov 19, 2008
ltfrc
  • 227 Answers
SOURCE: kds-50a2020 sony tv will not turn on
You may have luck in reading the blink code to find your problem at this link.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Posted on Mar 22, 2009
  • 13 Answers
SOURCE: I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
Posted on May 05, 2009
  • 178 Answers
SOURCE: When I power the TV on there is no picture, the
The squeeking sound could be the high voltage trying to strike the lamp, it will try several times to strike the lamp then shutd down. Take the bulb out and see if it s blown. Even if it is not blowen it sounds like you have a bad bulb.
Posted on Sep 01, 2009
Mitsubishi WD -60737 60" TV how can you check anything with no pic or sound
Bradley,
Can you power on the TV with a remote control or does it shut back off? When you hit the power button does it make a click noise attempting to come on and then shut off? Does the lamp light in the front blink?
I would check the lamp. I recommend Discount-Merchant for the replacement lamp... be careful buying from Amazon or eBay type marketplaces as they are infested with low quality generics!
Jan 15, 2014 | Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Get signal from tv that lamp is not working, been having an intermittent problem with it. What Ive done in the past is pull lamp and reset and it works, this time it doesnt want to come back up. The lamp...
hey there it sounds like you have a issue with the ballast board this is a common problem with this DLP TV's check out this link
http://www.fixya.com/support/r3556856-how_to_know_if_it_is_the_lamp_or_ballast
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 27, 2010 | Toshiba 56HM66 56" Projection HDTV
My samsung dlp tv sp50l7hx had to bemoved to lay
although the lamp may look ok your tv has all the signs of lamp fail they only need a slight bang. I know that it is cheaper to replace lamp than light engine
Nov 08, 2009 | Samsung SP50L6HX 50" DLP HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Samsung 46" DLP
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
