Question about Home Security
I need a video switching the camera viewing direction from vehicle signals. Where can I find one?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 74 Answers
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
How you make the camera work for front view on alpine INEw927hd? How do you connect the camera that came with the unit?
you must buy one of these camera and install one in the front of vehicle and one in the back to inew927hd. read the following (With front or rear camera installation, the screen on the INE-W927HD will automatically switch to your front or rear camera view. For the front of the vehicle connect the HCE-C212F or HCE-C200F and for the rear, an HCE-C210RD, HCE-C200R, HCE-C117D, HCE-C115, or HCE-C104. These camera systems will work directly with the INE-W927HD for a clean and easy install. For camera multi-view control directly from the INE-W927HD, the HCE-C210RD for the rear and HCE-C212F for the front can be used.) camera setuppage1 camera setup page 2 , camera setup page 3 depending on the camera installed certain cameras allow different displays on the video screen ... any more questions email me at radiorepair@windowtintingin239.com
Oct 27, 2013 | Alpine Car Audio & Video
Have sony xav-60 head unit trying to install a rear view camera, but having issues getting unit to switch over when in reverse what wires need to go where camera has yellow video output 1 red wire, 1 black...
You might try the truly wireless QuickVu(TM) Wireless Backup Camera. Run the yellow RCA cable from the receiver to your Sony unit, if it has an RCA input. The QuickVu camera has no wires, so that part is really easy. Buy direct from the manufacturer!
Aug 12, 2013 | Sony XAV-60 Car Video Player
Milion D1308 radio no video signal from rear view camera
i have an million d1308 stereo in my 2000 f150 my brother gave it to me and forgot the passwords for it how can i reset them or find them out
Feb 07, 2013 | Car Audio & Video
I can't seem to view my videos from the camcorder on my PC.
you need to have the proper connections on your PC "firewire" is one and the othere requires that you purchase an adapter (about 50 dollars US) that plugs into the USB port. this converts analog signals to digital which the pc can recognize. Camcorders like the one you have do not use USB directly.
Mar 19, 2011 | Sony Handycam DCR-TRV265E Digital...
We're does the rear view camra pos wire go for a lanzar sdn7ud unit
if i remember correctly, on your back up camera there are 2 wires a red one (power) and a black (ground). you will need to pull off one of the tail lights and find the reverse bulb/ wire. u will take the ground wire and mount it to the frame of your vehicle. then u will need to find the power of the reverse light. take the red wire and splice into the power of the reverse. u will then need a separate wire and run it from the spliced wires to your lanzar player. doing it this way will make the camera come on and the lanzar to switch to view when u have your vehicle in reverse
Mar 17, 2011 | Lanzar SDN7UD Car Video Player
Pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Feb 23, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Can I connect a miniature cctv camera direct to a dvd player to view live pictures and use it when reversing my camper van.
Yes you can.
You need dvd player with video in signal. This is a bit tricky to find.
You need miniature camera with video out plug.
You may need to find proper plugs for connection but a normal electronics store should have adapters if needed.
Cheers
TeaCii
Add sales support to you website for $1
Let security guard watch your cctv for a dollar
Feb 16, 2010 | Coby TF-DVD7005 Portable DVD Player
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
May 26, 2009 | HP Pavilion dv6000z Notebook
Not receiving a video signal out of camera
Let me know do you see live view in camera mode on LCD or view finer?
If yes then check AV (audio-video) cord hooked with camera and better to get another AV cord to test.
Let me know if need further help.
Jan 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Home Security Logo
142 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
