Question about Home Security
Where can I buy a security monitor that is a wide-screen LED Monitor
    Problem Solver:
  • 53 Answers
2 thirds screen good other third Vertical lines do I need to replace monitor
Simple answer is yes. BVuy a new one.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | AOC E2250SWDA 21.5 WIDE LED MONITOR
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
How to solve half display of my LED monitor was corrupted
Not you monitor corrupted i think your monitor screen regulation problem so first of all check you monitor regulation is ok or not. Then you decide monitor scree corrupted.
Thnaks..
Sep 06, 2013 | BenQ GL950AM 18.5 WIDE LED MONITOR
IS old stle monitors better than widescreen and what is the best ones of both with a high ratio under $150
I suggest you Google the Internet for 20" LCD monitors. You will get a price comparison between the various suppliers.
Dec 21, 2012 | Computers & Internet
My monitor fell on the floor and now my color is off. the color is darker on the left of the screen. Do I need a new monitor now?
I suggest you to buy a new monitor because it will be expensive to replace the LCD. You monitor LCD is damage that is reason why there is a dark color on the left screen.
To avoid any harmful accident in the future. Because it will create electrical spark inside the monitor which will be burn out the entire monitor or maybe result to smoke. There is no remedy in that particular trouble but to replace the entire LCD. But this is not advisable because it will cause you expensive cost of repair.
You need to buy new monitor and I suggest if you buy new monitor. Buy LED monitor which is better than LCD. LED monitor is a green campaign of every manufacturer due to energy saving specification and have a better graphics than LCD...
Hope this will help you a lot. If you any other question please don't hesitate to contact me
Sep 16, 2011 | eMachines E211H Monitor
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
What large lcd monitor can I buy that will best display a full 8.5x11 page and still let me be able to read the type?
Some wide-screen monitors have a "rotate" option in the software that comes with the monitor -- you physically rotate the screen 90 degrees, and then Windows will rotate the entire "desktop" so that you now have an "extra-tall' screen, instead of an "extra-wide" screen.
Jun 09, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
Open lg 22' wide screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 13, 2010 | LG 22" FLATRON LCD Monitor
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
There is a 4 inch wide back vertical strup down the diplay screen
It is probably be a faulty LCD crystal, or a bad internal connection where the electronics meet the LCD. I would think it could happen if the monitor is jarred or dropped, I guess it could occur also if the monitor was brought in from the cold weather and condensation occurred inside?
Unless you have access to a trained LCD technician, your only option is return the monitor for exchange or repair, or buy a new one.
Apr 03, 2008 | Westinghouse LCM-19v1 Monitor
Home Security Logo
144 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
