Question about HEWLETT-PACKARD Pavilion dv7-1247cl (884420770190) PC Notebook
Drive taflag 39 - HEWLETT-PACKARD Pavilion dv7-1247cl (884420770190) PC Notebook
Hard drive won't reboot (jumpers not set proper)
Just google your drive's make and model and search the results for a diagram of the jumper settings.
If you have a SATA drive, there ARE no jumpers. If the drive is a PATA, then if it's connected with another drive or cdrom, then make the cdrom 'slave' and the disk drive 'master'.
Check your bios setting sometimes bios changes the boot order esp. if bios doesn't find a boot disk- make sure you have your desired boot device showing in the boot setup.
Oct 31, 2012 | Hitachi Computers & Internet
I cnt open my pen drive..it's showing insert disk..it is a cruzer blade 16gb pen drive..and I have a windows XP..
Windows XP should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 09, 2012 | SanDisk 8gb X2 = 16gb Cruzer Blade Usb...
Please say someone has a solution for me, very worried i've most my life's collection of music and movies =[
Try the WD USB hard drive in another computer. If you can access your data on another computer then backup your data.
If the WD USB hard drive is faulty then -
It is not possible to recover data from faulty hard drivesby mortals such as you and I.
There are companies that can recover data from faulty and damaged hard drivesBUT they wll charge an arm and a leg for their services.
Feb 23, 2012 | Western Digital 1TB WD ELEMENTS USB...
Can't access files on external hard drive
Hello Amelia.
For your problem please connect your external drive and try these steps.
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select change letters and path
window will pop up then click on add
select any letter not in use and click on ok.
I Hope this helps. Dale
Dec 20, 2011 | Seagate 1TB FA GoFlexDesk USB20 Blk
Samsung format sgh-790
Hello xanxi_uki, to "Format the Sandisk;
You can (right click), or 2x click to 'open' the "Computer" from the Desktop!
This will 'open' the Computer's Hard Disk Drives.
Or you can click on the "Start Button" and 'open' the "Computer."
Once you are in the Computer Drives; find the "USB Flash Drive."
Next, (right click) to 'open' the 'shortcut menu', choose to "Format."
In the Format UDisk (?), click on the "File System" [Drop down arrow "Box"].
Choose the [NTFS] from the list !
Select 'how much' of the USB Flash Drive you want to use?
This will be in the "Allocation unit size" box !
Now, you want to choose to {Quick Format} the USB Flash Drive.
"Place a [check] in the "Box" by clicking on it, to do so.
Next, click on the [Start] button."
The "formating" of the (USB Flash Drive) will begin.
Once it is 'finished'; use it as you like.
"If you need help with anything else?
"Write a 'comment'; I'll be on "Stand-by!"
If all goes well? Give a "Helpful Rating", thanks, paul7of9
Oct 02, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i turn it on it says BOOTMGR is missing press crtl+ alt +del to restart.
Hello ronnie_fun41, for the CPU to: Find the OS!
Follow these instructions
To get the Computer to "Boot into the 'OS,' and Loading Windows."
  • Restart the Computer
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12} button.
  • This will open the "Boot Menu:" [Priority Boot Sequence] window.
  • There will be a "list" of (Devices), Optical Drive / CD, SATA / HardDisk Drive, or USB...
  • I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files.
  • It may also hold the "Master Boot Record" or Boot.ini file?
  • So, what you need to do is give the Drives a "Priority Boot Sequence," meaning , you will 'place' the Drives in the 'order' of Bootup [First] listings.
  • You will use the {Arrow buttons} to 'move the "Drives."
  • More than 'likely' it will be the (*Optical Drive / SATA or Hard Disk Drive}.
  • Try each, and hopefully the Computer will make it to "Windows," and you can "Login!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
Oct 01, 2011 | Acer Aspire One PC Notebook
I have a dell dimension 3000 series desktop and when I turn it on it does not get passed POST and tells me the following: primary drive 0 not found primary drive 1 not found gives me the option of F1...
This normally means that the Hard Drive is not recognized, and most likely can be attributed through a crashed hard drive. If it's not POSTing, then I think you need to look for loose cords/cables as well. That can cause the hard drive to not be recognized.
Jul 07, 2011 | Dell Dimension 3000 PC Desktop
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
After installing a sata drive with xp home i took my old hhd and put it on the cable with another hhd on the same cable . Now mthe primary hd 0 and 1 are not found and f1 to continue then it will load x...
First, do you have a 40-wire or an 80-wire parallel-ATA ribbon-cable?
If you have the 40-wire cable, you need to set the jumpers on both of the old drives.
Set one disk-drive to 'master' (maybe also add 'with slave present').
Set one disk-drive to 'slave'.
If you have the 80-wire cable, you need to set the jumpers on both of the old drives.
Set both disk-drives to 'C(able)S(elect)'.
Is the new SATA drive just a "data" drive, or did you install Windows onto it?
May 27, 2011 | Computers & Internet
HEWLETT-PACKARD Pavilion dv7-1247cl (884420770190) PC Notebook Logo
24 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
