Question about HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard P/N: 417035-0...
Dell p10f when is power no my leptop, cannot display anything.i also try to open Bios but it also cannot display but cpu fan is running, what is the problem of this error?
  • Dhaneshwor May 10, 2013
    i did the Ram also check and refitting again but cannot display but after few minutes it also shut down automatically.
  • HP Master
  • 3,799 Answers
Try refitting the RAM.
Posted on May 09, 2013
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Dell optiplex 760 tower fan noise problem
Its important to try and distinguish where exactly the noise is coming from the most typical example of this is the PSU fan (Power Supply Fan). The above also is very correct but its better to eliminate each point of failure.
May 08, 2014 | Dell OptiPlex 760 PC Desktop
Optiplex 320 wont boot. Amber power light and fans running
power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Feb 17, 2012 | Shuttle sn Computers & Internet
Cpu fan fast bios wont start
Run the Dell Diagnostics to test the Fan.
Check to make sure the fan power connector is connected to the mother board.
The fan could be defective.
Reset BIOS to factoiry default settings.
I hope this helps.
Good luck and have a pleasent day.
May 16, 2011 | Dell Dimension 8400 PC Desktop
Hi,I have a Dell Latitude D600 which the temp are always at 85.5C(mobmeter,ig8kfan). The fan was running high all the time n the speed is just 600mhz instead of 1400mhz whatever i do.(Prime95,Dell Xp...
don't worry most laptops nowadays run hot. your CPU will shut itself down long before damage occurs. try elevating your laptop to promote air circulation or place it on a cooling mat.
Be careful if you set it on your lap, some people have had minor burns from laptops setting on their laps for prolonged periods.
Jan 04, 2011 | Dell Latitude D600 (D6005C) PC Notebook
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
When i connect my cpu to monitor i cannot get the display
try reseating the memory, looks like this:893eaf5.jpg
or clear the cmos
kind regards and please don't forget to rate
Dec 01, 2008 | Gigabyte GA-8I865GME-775 Motherboard
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  P/N: 417035-0... Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
