Question about Home
I am looking for plastic containers in portion sizes to fit inside my lunchbag for work.
    Problem Solver:
  • 54 Answers
Compartmentalized BPA-Free Plastic Food Storage Containers w/Easy-Open Lids (Not Leakproof) http://www.easylunchboxes.com/products/food_containers/index.htm
Posted on May 09, 2013
How to unjam the lid to an OXO Good Grip Pop Container
replacement parts can be found easily on amazon. here: Amazon com OXO Good Grip Pop Container parts I hope this was helpful. Cheers
Mar 20, 2013 | Oxo Good Grips POP Rectangle Storage...
Haw to remove oil of bajaj discover 100
How to remove Bajaj Discover 100cc Engine Oil Any budy explain me .
Jul 05, 2012 | Bajaj Discover Motorcycles
Unit not discharging through garden hose. Just cleaned unit inside and out. Works great, BUT, only discharges into its container. What am I missing. Cleaned all hoses - no blockages. What should I be...
The blockage is not in the hose, it's inside the hose connection drain tube. To clear this clog, you will need an 18" long plastic Zip Tie, sized to fit into the drain hole. You can use something similar, but NO wire coat hangers. Carefully thread the Zip Tie into the hole and continue to firmly, yet gently work it in, until it reaches a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of Zip Tie. Then slowly pull it back out while rotating it. This will help remove the clog. Once you have pulled it almost all the way out, be prepared for some water to follow.
That should solve the problem for you. Please let me know. Thanks.
May 26, 2011 | Danby DDR586R Dehumidifier
Frydaddy plastic lid melted. What diameter glass lid might I use to replace it?
I don't have a glass solution, but if you frydaddy is like mine, it has a 7.25 inch dia lid. For about $2 the "Glad Big Bowl" (6 cup size) plastic containers have a lid that fits pretty well.
Jul 15, 2010 | Presto 05420 FryDaddy Deep Fryer
Need to replace gas filter but looks like i need a
This special tool is available at your local auto parts store. Ask your parts expert what size you will need. The tool is fitted around the fuel line and pushed into the fitting on the filter. Make sure you relieve the fuel system pressure before proceeding.
Oct 29, 2009 | 2001 Chevrolet Silverado 1500
2001 Kia Rio Cooling is leaking from hose near to the radiator cap.
The small[pencil size] hose connected just below the radiator cap & to the plastic coolant reservior is the coolant over-flow hose,allowing the coolant to flow into the tank as it expands from being heated,and return to the system as it cools.If the leak is near the radiator fitting,possibly damaged portion can be cut off while engine is cool,and hose re-fitted.Replacement tubing is available at auto parts supply stores,identifiyed by it's inside diameter measurement.
Oct 21, 2009 | 2001 Kia Rio
Need to know how to change the air filter in a 2004 Dodge stratus
Well that?s easy, its right there on top, inside the black plastic assembly. Just pull it out, remove the filter, stick in a new one. With the hood open, and you are standing there, look down at the right hand side, black plastic container with a large air hose coming out from the left side of it. On the 2.4L engine, you just pull it out towards the left, on the other engines, it's a little different, look at closely, you will see how it just fits in there.
Jun 07, 2009 | 2004 Dodge Stratus
Empty old toner
Open front cover of your 2060. Inside the copier, on the left side, there is a blue lever labeled "A". Press lever "A" towards the left while pushing down on the top of copier....this will unlatch the **** shell and allow the upper portion to lift upward. The waste (used) toner container is located in the center of front frame (semi-clear plastic). Lift upward on container until it clears the frame, CAREFULLY pour the contents into a plastic lined trash can. Replacement is reverse of removal.
Jun 05, 2009 | Toshiba 2060 Copier
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Home Logo
922 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
