Question about Sony Handycam DCR-DVD201 DVD Camcorder
Lid will not open!
The lid on the camcorder wont open :[ When i try to open the lid, it says 'Preparing to open Cover' .. Then like 20 minutes later it says error, and it continues to stay stuck. Also, it wont turn off. I haven't called the Sony company and the Geek Squad at the Bestbuy we purchased it at hasnt helped at all .. my bloods beginning to boil.
  • lindaart Dec 23, 2007
    My cover would not open and we pryed it open but it still says lid is open and will not record.
  • 38 Answers
There is no easy solution. Qualified Sony servicers have a service remote that connects to the lanc jack. There are hexadecimal codes supplied in sequence to cause the micro to output a signal to open the door. However, disassembly by a qualified tech can allow mecahnical release as well. I can tell you this is not an a do it yourself fix. This particular model once it is unhappy with a disc will never open, the problem was irradicated in subsequent models. Third party brand discs and discs with surface marring, especially fingerprints, will lock up the works.
Posted on Aug 12, 2007
SOURCE:
Buttons work, but the safety feature wont let it run unless I lean on the lid
Don't know if it's a front loader or a top loader. Either way, there is a safety switch in the lid. On a top loader, there is a little button at the back of the lid opening, which the lid pushes as it closes. the lid may be out of line, or warped. Did anybody stand on the lid ? If bent, try to twist the lid straight. You may also try temporarily wedging a folded matchbook cover between the lid and button until you can fix it correctly.
Mar 07, 2015 | Washing Machines
Where can I find the instructions Manual?
To insure long life and satisfactory performance from your Nordic Ware Rice Cooker, follow these simple guidelines (microwave use only).
1. Before using your Rice Cooker wash it thoroughly by hand in warm soapy water or in the dishwasher (top rack only).
2.Foods with strong colors (particularly red sauces, tomatoes) may stain your cookware.Staining that may occur will not affect the use of the cookware.
(Cooking times may vary due to variations in microwave ovens.Adjust cooking times for best results in your oven.)
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2.Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
HELPFUL HINTS TO ENHANCE THE FLAVOR OF ANY MICROWAVE DISH:
1. Use chicken broth instead of water for added flavor.
2. Add a little butter or oil to contents.
Jul 30, 2014 | Nordic Ware Kitchen Appliances - Others
My washer is locked won't open
Will Not Unlock
• Press off. The motor control is not responding if it
takes 4 minutes to unlock. The motor control is
either bad or disconnected.
• Unplug and reconnect power cord. Wait 20 seconds
for machine to unlock.
• Check lid locked switch circuit. Circuit should be
closed at machine control.
• Check for loose electrical connections at lid lock and
at machine control board.
• Push lid closed to make sure nothing from inside is
pressing against it which may keep it from unlocking.
• If necessary, remove clothes by disconnecting power
to washer, and open top cover with a putty knife.Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | Maytag Neptune FAV9800AW Top Load Washer
It wash and evacuate the water but doesn't spin at the end!! What can I do?
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Washing Machines
Washer wont operate even with lid shut. I have to push on lid until it starts.
Sep 09, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Wont spin or drain
Hello , this might help you.
Jul 31, 2011 | Washing Machines
Cover open
find out where the pressure sensor is to close lid and use something to hold it down. with the lid up. then see if the id goes down in the right place. the cartridge should run accross when the lid is down befor copy one.if it does not try reinstalling printer. but remove old one first. make sure you have the disk. try paper jam button. as well. if none of above contact maker for solution.
Mar 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
Cooking Pasta:
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Dvd door wont open
Some part of the ejection system is malfunctioning possibly due to bent or broken latching components. Take unit to pro tech
Jul 13, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
247 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
