Question about Pool & Spa
Make - BAUTZ Type- 6411-PB4-C-N-K - Pool & Spa
The PB4-60 doesn't fit
They changed the design of the pump a few years ago when Zodiac bought out Polaris. Re-plumbing isn't that hard to do, but if you are not comfortable with it a pool tech or handyman should be able to do it for about $60.
Feb 10, 2014 | Polaris Pb4 - 60 Booster Pump
Battery not holding charge and power lead has to be held in position for charging to take place
Use an ESD wrist strap with it's alligator clip attached to a good ground source.
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Disassemble the laptop, remove the motherboard.
Replace the DC Power Jack. http://www.laptopdcjack.co.uk/product/Advent_6411_DC_Power_Jack_Socket_DC-ADV-6411
Information that may help to disassemble,
http://www.adventsupport.com/viewtopic.php?f=1&t=6770
http://www.uktsupport.co.uk/advent/laptop/6411v.htm
ftp://ftp.packardbell.com/pub/itemnr/7602080000/Disassembly_EasyNote_MZ_rev_100.pdf
(Advent 7211 series is like a P.B. MZ35 series. Just thought it may help)
http://www.youtube.com/watch?v=Im_n9K-14_I
Regards,
joecoolvette
Nov 25, 2012 | Advent Computers & Internet
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
I am replacing an older polaris pb4-60 with a new polaris pb4-60...when moving the power cord to the new pump i have 3 wires, a green, black and yellow...I know the green is the ground, but which poles do...
if across the black and yellow you have 220 volts ac then wiring from factory ok black to L1 yellow to L2 and green to ground or case if 120 volts see side of motor for wiring
Jun 09, 2012 | Polaris Pb4 - 60 Booster Pump
Remote for jensen mpx 6411
Setup codes for Jensen are:
0004 0009 0133
Apr 28, 2012 | Jensen Televison & Video
I need an autorization code for cs2 version 9. My serial number is 1045-1085-6610-5394-9391-9263 and activation number is 6684-6411-9718-4688-9893-6285-4031, activation type normal 93: -8. Please help me,...
Im sorrryHi ,
You need to go to www.adobe.com/photoshop and go to support and see if that helps by bring up your question or you can contact them through email , im sorry I could be of more help . but im sure they will help you ........Good luck Roy
Oct 25, 2011 | Adobe Photoshop CS2 for PC
I need pb4-mx driver
Since this is an HP product, you can go to their website.
http://www.hp.com/#Support
Then you need to type in the model of your system. It will give you the drivers you need
Jun 26, 2009 | HP Computers & Internet
Pool & Spa Logo
80 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
