Question about Home
Where can I purchase a hot/cold wheeled cooler?
    New Friend:
  • 44 Answers
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Need new faucets for Sunbeam water cooler
hot and cold water have a smel, do I have to clean or replace sonthing?
Sep 12, 2010 | Avanti Hot and Cold Water Cooler
Have a bmw 316 it over heats when stopped after bout ten mins with the engine still runnin,, also the fans r blowin cold
feel your radiator when the engine is hot, should be hot at the top and cooler as you go down with no cold spots, if you have a cold spot then it is clogged, and it will require cleaning or replacing. Check your thermostatic fan clutch when the engine is hot should be hard to turn, if it free wheels while engine temp is more then normal, it probably needs to be replaced. Hope this helps, let me know
Dec 14, 2009 | 1996 BMW 318
On top of the water heater, which is the hot input and which in the cold input
cold input & hot out put, facing the front of the water tank it is usually the rear which is hot out out.
Oct 17, 2009 | Hamilton Beach Water Cooler with Storage...
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
May 29, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
Dec 18, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Home Logo
430 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
