Question about Franke Evolution
Franke evolution basic - heating sensor 1 , locked selection
When i switch the machine on from standby , the display screen shows **flashing** heating sensor 1 & locked selection . it stays on till i off the machine .. and im also unable to dispense coffee or hot water because of the flashing display .. help please (:
5 Suggested Answers
  • 29 Answers
SOURCE: We have a Franke Evolution
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
Posted on Nov 19, 2010
mikey270
  • 26 Answers
SOURCE: I have a franke flair coffee machine when you
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Posted on Jan 29, 2011
coffeefixer
  • 53 Answers
SOURCE: not a problem more of
the evolution is a super automatic ,im not sure what you mean by water processed? but i do know you need water with a low ppm of hardness or you risk ruining the machine. water processed refers to the way beans are prepared, usually decaf.
Posted on Sep 06, 2011
  • 13 Answers
SOURCE: Franke saphira will not exit rinse unit, will not
check the flow meters
Posted on May 10, 2012
Why won't my Franke flair machine won't run only says please wait.is there a reset switch ?
there is no reset switch, please wait on the display indicates the machine is heating . but the sensors are not registering the temp. this means either the thermoblock/s have failed (unlikely) there are upto 4 thermal fuses mounted on the thermoblocks . this is more likely the problem. any more info required please et me know
Jan 10, 2015 | Franke Flair Espresso Machine with...
How do I wire a Franke Evolution 2-step
There are other points to consider before wiring in the machine. is it a topps model? 2 boilers?
singer boiler with heat exchange unit. are you wanting single phase 13 amp 22amp or 3 phase.?
you can email me direct on franke@lydney.biz
Dec 22, 2014 | Franke Evolution Two Step Espresso Machine
Erro temperature sensor 1 franke sensor
the coffee-boiler is not heating up. check the clicksons (push the little red button in the middle of the clickson to rest). heating element can be broken too. btw: the coffee-boiler is littlest boiler.
Aug 23, 2014 | Franke Evolution
Error 44 time out motor
Could be faulty design.
Apr 17, 2014 | Franke Evolution
Franke evolution no install card
try ebay. password for card once entered is 1000 or 0001. install cards are only given to franke trained engineers.
Jan 08, 2014 | Franke Evolution
Not a problem more of a question. Is the Franke evolution espresso machine a water processed machine? Also what does that mean for it to be water processed? THnak yOu
Sep 05, 2011 | Franke Evolution
We have a Franke Evolution coffee machine and the fault 'E43 Motor Time Out' error keeps appearing. Could you please advise me what this fault is. Is it related to the upper head micro switches and if so...
Sep 30, 2010 | Franke Evolution
Gaggia Evolution Espresso won't heat up
1 heating element defect(needs replacement)
2 security termistat, (replacement or reset)
Mar 25, 2009 | Gaggia Evolution Espresso Machine
Coffee Makers & Espresso Machines Logo
112 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
