Question about Franke Evolution
Franke evolution heating sensor 1 , locked selection
When i turn the machine on from standby . the display shows *flashing* heating sensor 1 & locked selection ... unable to dispense coffee and hot water .. i think the boiler is not heating up
  • 29 Answers
SOURCE: We have a Franke Evolution
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
Posted on Nov 19, 2010
  • 29 Answers
SOURCE: Franke Saphire Coffee Machine when turn keeps coming up with Mulf
This is due to the failure of the brew system, 1, an o ring on the brew piston may have failed
2, the brew unit may have failed - Replacement will be required. 3, the brew motor may have failed - replacement will be required , 4, numbers 2 and 3 ...
The brewer and motor are not really serviceable (labour intesive) replacements are more economical. have to hope its just the O ring!!!!
coffeefixer
  • 53 Answers
SOURCE: The boiler in my Franke
you most likely need a new pressure stat/switch as it is what tells the elements to turn off and quit heating.
Posted on Sep 01, 2011
coffeefixer
  • 53 Answers
SOURCE: not a problem more of
the evolution is a super automatic ,im not sure what you mean by water processed? but i do know you need water with a low ppm of hardness or you risk ruining the machine. water processed refers to the way beans are prepared, usually decaf.
Posted on Sep 06, 2011
  • 13 Answers
SOURCE: Franke saphira will not exit rinse unit, will not
check the flow meters
Posted on May 10, 2012
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
My washer is French how do I change it back to English
1. Turn the power on at the wall socket.
2. Select ON/OFF at the console so that there is nothing showing in the display - ie: machine OFF.
3. Press & hold the 2nd, 3rd and 4th function buttons until the machine BEEPS (approx. 5 seconds). (centre 3 buttons below the display).
4. Select ON/OFF at the console to turn the machine ON so that the display is ON - it should now show language options scrolling through.
5. Wait until the language you want is shown or scroll through them manually using Spin Speed or Temperature then press Child Lock to select it.
Hope this helps
Mar 18, 2015 | Hotpoint Washing Machines
How do I wire a Franke Evolution 2-step
There are other points to consider before wiring in the machine. is it a topps model? 2 boilers?
singer boiler with heat exchange unit. are you wanting single phase 13 amp 22amp or 3 phase.?
you can email me direct on franke@lydney.biz
Dec 22, 2014 | Franke Evolution Two Step Espresso Machine
Erro temperature sensor 1 franke sensor
the coffee-boiler is not heating up. check the clicksons (push the little red button in the middle of the clickson to rest). heating element can be broken too. btw: the coffee-boiler is littlest boiler.
Aug 23, 2014 | Franke Evolution
Franke evolution no install card
try ebay. password for card once entered is 1000 or 0001. install cards are only given to franke trained engineers.
Jan 08, 2014 | Franke Evolution
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Yves
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
