Question about Denon DCM-35 CD Player
Denon UD-M50 amp/3 cd changer
Cd auto changer reciever. have had 5 years or so but hardly used. Volume started to independently/ spontaneously increase rapidly to max volume today when on moderate volume setting. Turned unit off. When turned on again, the same happened. Pattern repeated again a third time after having played normaly for 10 minutes or so. Any explanations and, ideally, solutions?
  • 3 more comments
  • doctordoom Aug 13, 2007
    Don't really understand the advice
  • Anonymous Dec 14, 2007
    I have the exact same problem with my denon ud-m50. In addition to the volume going up by itself when I turn the volume down it goes up...WTF?
  • Puzzled-101 Jan 27, 2008
    I have the same problem with my Denon AVR-1802 receiver. I've had it for 5+ years with no problem. Then a couple days ago the volume spontaneously increased to max volume four different times. When I called around to some service dealers they didn't have an answer. Most said they hadn't heard of such a problem. Glad to know I'm not the only one experiencing this phenomenon.
  • dougdenon Nov 28, 2008
    I have a very similar problem with my 7 year old Denon AVR-1802. The receiver will spontaneously go to full max volume (+18 on the front panel) in about 1 second. I have no solution.
  • Puzzled-101 May 11, 2010
    Hi doctordoom and Guest,
    Was just wondering if you ever found a solution to the spontaneous volume increase problem with your CD players. My Denon receiver only did it that one day, but I'm curious to know if yours continued to be a problem and if you ever found a fix for it.
    Thanks!
    President:
  • 3,130 Answers
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Posted on Aug 13, 2007
Cd stuck in Denon CD auto changer receiver. Displays ERR. How can I get out?
As there may be other factors at play that require a more detailed explanation, I would suggest that you seek a resolution through a discussion with a qualified technician. To do this, refer to your operating manual, which should provide a telephone number for technical contact assistance. You can also go up to the manufacturer's website and make contact for advice. www.denon.com/
Mar 05, 2015 | Denon Audio Players & Recorders
How do i reset my denon UD-M50?
Download the user manual to this set by net. It will have all details.
May 28, 2012 | Denon Audio Players & Recorders
CD not ejecting - Denon UD-M50
Check its loading belt. It might be broken or the gear wheel assembly have damaged gear wheels. The fault is with its loading mechanism. Sometime, replacement have to be done.
May 10, 2012 | Audio Players & Recorders
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
I have an denon ud m50 multi cd player and reciever some one tried to put more than 1 cd in the same tray and it now will not accept any so its a mechanical problem can this be fixed and if possible...
Yes this is fixable by rebuilding the loading mechanism. As long as the mechanism is just jammed and no parts are broken, this should only cost the labor charge at a local service shop. I have done a number of these in the past and while not the simplest of mechanisms, it is fairly straightforward.
Dan
Aug 26, 2008 | Denon Audio Players & Recorders
Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your denon UD-M50 I might be able to help. I have fixed a number of them in the past and have the necessary maintenance manual and knowledge of a company that can supply spare parts. Disassembly looks very complex, especially when the problem is with the carousel but once you have an understanding of the mechanism it's not that difficult. Care should be taken when manually removing and reloading the disc trays as damage can result to the 'Teeth' alongside each. Spare trays are available. All my repairs involved the removal of the carousel mechanism in order to align the trays. I can copy the relevant sections of the manual dealing with the re-alignment which is critical but again if followed exactly you should have no trouble. If you respond with an Email address, I will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
Nov 15, 2007 | Denon D-M50S CD Shelf System
DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Oct 10, 2007 | Audio Players & Recorders
Denon DCM-35 CD Player Logo
738 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
