Three seperate batteries charged with Ryobi (P110 140237021) charger don't bring much juice to Ryobi 18v drill driver (MN: HP1802m). I am able to stop drill with my hand in both speeds.
Batteries, charger, and batteries are all app. two years old.
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
the drill can run fine and then quit without moving the trigger. I can rotate the chuck by hand (no...
(More)
the drill can run fine and then quit without moving the trigger. I can rotate the chuck by hand (no torque) without necessarily making the motor restart. Batteries are fine. Should I replace the drill, replace the switch or something else?
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops....
(More)
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops. might be a gear problem? How do i fix?
Have a pivot plus for several years and it always recharges. This time after several hours, it was...
(More)
Have a pivot plus for several years and it always recharges. This time after several hours, it was dead - no nothing. used the same charger(we marked it so we would know it). If its' integral battery is dead can it be replaced or is it too expensive and more trouble than buying a new one? Thank you
