Question about Toshiba TP55H60 55" Rear Projection Television
Toshiba TP55H60 power down after start up
If I uplug the tv for a little while and plug it back in,it turns back on for a very short period of time,then it shuts off and the blinking red lights occur.It will not turn back on until I unplug it for awhile,and then try again only for it to shut off again in about 20 seconds.I have had the tv for 8 years and would rather try to fix it rather than let it go,it still has a great picture and sound.Any help would be appreciated,thank you.
  • 5 more comments
  • atyeung May 17, 2008
    I have the same problem with my eight year of TV. Each unplay allows it to stay on for about 5 minutes. It does not seem to be the sleep timer or the auto turnoff when TV signal is missing.
  • Anonymous Jul 29, 2008
    I have the same problem. I'm going to try and remove the convergence module as all "flashing red light" issues seem to point to it! I'll keep you posted
  • Anonymous Aug 07, 2008
    I've got the same problem. From what I've read it apprears the convergence IC's have gone bad. I have ordered new ones and will replace them. I'll keep you posted on my results.
  • winzells Aug 13, 2008
    I have the same problem. TV powered down and red power light started blinking.
  • Anonymous Aug 22, 2008
    I tried changing the IC's and did get much luck. Now I get an immediate flashing light....Perhaps the new IC's need to be calibrated or something?
  • Anonymous Sep 07, 2008
    I replace the IC's with some I purchased from e-bay and instead of clicking off after 2-3 seconds, it turns off immediately. Replacing the STK-392 IC's didn't work.... I'll see what else I can come up with next.
  • John King
    John King Feb 13, 2018
    did anyone figure out the real fix for this ? power board ? mine works after unplug and a smack, still turns off sometimes tho.
Try the following
1-unplug tv
2-remove bottom cover on tv
3-tap the power supply frame a few times (where the power cord enters the tv)
I had the blinking red light on my tv. I tried other solutions like removing the red wire a few times etc. Tapping the power supply frame solve the problem.
Posted on Jun 18, 2008
    New Friend:
I tried the solution posted by pmcaire (tapping the power supply frame) and it worked. The tv is working now and I was able to cancel a very expensive service call this morning. ($325)
Posted on Dec 14, 2009
    Problem Solver:
  • 3 Answers
This most likely is the IC Convergence chip STK392-150. I ordered some on E-bay and the solution did not work. I believe there was a resistor or capacitor that also needed to be replaced so when I plugged in the TV with the replace IC convergence chips, they just popped again. I had to send it to a Toshiba repair show which charged me 400 bucks to fix it. That was 9 months ago.... Guess what, same problem again. Blinking red light. Time for a flat screen.
Posted on Aug 21, 2009
I had the same problem a few years ago and had a tech come out . It was a bad resistor easy fix. Hard part was having the tv not work when tech was here to trace the problem.
Posted on Aug 01, 2008
    Sergeant:
    Champion:
  • 375 Answers
Possible cold solder connections given the age of the unit.
Posted on Sep 11, 2007
SOURCE:
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
TV TURNS ON AND OFF BY ITSELF
check the fuses, I have the parts if you need them. hill6399 at yahoo.
Oct 22, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba 55inch rear projection.
Check your connections to make sure they are not loose, also if you pull the boards check for burnt solder points. I have parts that are good if you want them, very cheap. Email me at hill6399 at yahoo.
Mar 16, 2008 | Toshiba TP55H60 55" Rear Projection...
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Design Problem of TP55H60
call tech ..suggest soldering h-drive.
Jul 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Toshiba TP55H60 55" Rear Projection Television Logo
381 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
