Question about Dryers
How to reset error code F11 in Bosch Maxx 7 dryer
When it is switch on error code F11 appears and it does not turn
5 Suggested Answers
SOURCE: Bosch maxx 7 sensitive dryer wich stops everytime
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Posted on Feb 22, 2011
kevin_getz
  • 1031 Answers
SOURCE: Bosch maxx 7 condenser dryer not working after power surge
Most likely, the surge blew the internal fuse. I would try replacing that first. If you can't do it personally, have a certified tech do it for you.
Posted on May 08, 2012
richroth
  • 9472 Answers
SOURCE: bosch dryer error code F11
Sorry to be the bearer of bad news.
F11 indicates a fault with the main control board.
Posted on Nov 01, 2012
richroth
  • 9472 Answers
SOURCE: My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Posted on Nov 05, 2012
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 error code
    I appreciate the post, dan moore!
    From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
    Dec 14, 2014 | Frigidaire Kitchen Ranges
    Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
    F11 - Drainage fault
    This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
    Background information:
    After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
    Cause: Drain blocked.
    Remedy:
    1. Clean the on-site drain.
    2. Check the sump drain.
    3. Check the filters.
    4. Check the heater pressure switch and replace it if necessary.
    Cause:
    Ball in non-return valve in sump has not opened (e.g., jammed).
    Remedy:
    Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
    Remedy:
    Clean the drain pump and its impeller.
    Cause:
    Drain pump defective.
    Remedy:
    1. Check the voltage supply to the drain pump.
    2. If correct voltage is present, check the drain pump motor winding.
    3. Replace the drain pump, if necessary.
    Cause:
    Foreign objects in heater pressure switch.
    Remedy:
    Check the heater pressure switch for blockages and correct switching point.
    Cause:
    Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
    Remedy:
    Replace the heater relay.
    In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
    Hope ths helps.
    May 20, 2011 | Dishwashers
    Problem with code F11 on Estudio 311c - aspanner
    [F11] Communications error between system-CPU and scanner-CPU
    This quite often can be cleared up by resetting the machine. If not you will want to check all of the connections between the scanner, the scanner board and the system boards in the back of the machine. If nothing is loose this is likely a very critical error and you will need to have a toshiba authorized technician take a look at your copier.
    Sep 08, 2010 | Toshiba COPIERS - E-STUDIO 311C Copier
    Stops on spin cycle and gives a f11 error code
    F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
    Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    F11 & FDL error codes several times per load.
    HI. this is a door lock error code.
    A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
    Potential Causes
    • Door Lock Mechanism broken or removed from the Door
    • Check Door Lock/Switch Assembly
    • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    • Door Lock/Switch Assembly Failure
    Replace failed component.((Which will be a failed door lock assembly in this case))
    Aug 31, 2009 | Kenmore Washing Machines
    F11 fault code
    Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
    1, Power off at the machine. Do the next 4 steps within 3 seconds.
    2, Press Temperature Button in.
    3, Power on
    4, Release temperature button
    5, press Soil Type button
    You will now hear the door lock release so you can get to your pants.
    Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
    I am sure it would help you to resolve the issue.
    God Bless.
    Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
    Dryers Logo
    902 people viewed this question
    Top Dryers Experts
