Question about RCA HD52W59 HDTV Projection Television
No Picture/No Sound
RCA HD52W59 HD Projection TV purchased around Feb 06. Yesterday, after watching TV for approx 10 min. the pic/sound just shut down. The unit has power as confirmed by the green light when pushing the power button. The green light flickers and I can hear a "humming/whining" type noise as if the unit is trying to start up, but after a few seconds - the green light goes off without successful start up. Help - I'm 50 miles from the closest RCA service center. I know it's the TV, not the wall outlet, as I've used that outlet for other appliances with no problem since. Could the TV be damaged from a power surge??? Is this something I can repair myself? Is there a schematic avail? Thanks in advance for your help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Posted on Sep 06, 2007
I have a 52'' rca hd52w59 i have sound but it takes some time for the picture to come in a when it does its not clear it take about 40 mins an then its fine
as this is a rear projection tv, I wonder if the lamp is fogging up when not in use? is the area where the tv is situated damp at all or could something have been spilt into the set?
May 03, 2011 | RCA HD52W59 HDTV Projection Television
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Mar 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
