Question about Minolta EP4000/5000 CS/PRO Copier
Ep cspro the machine ask the code m2?
  • Minolta Master
  • 6,161 Answers
Replace the WASTE TONER bottle. NOT The toner bottle. Once you installed the new one clear the counter in service mode.
Posted on Jan 31, 2015
5 Suggested Answers
  • 11 Answers
SOURCE: cspro ep 5000
sorter problem
Posted on May 07, 2008
  • 17 Answers
SOURCE: Minolta CSPRO EP 3050 turning it On appears display Code: C0200
A C0200 is a problem with one of the coronas - could be the charge, transfer, or separator.
First try resetting the code by opening and closing the main front door with the machine powered up and the error code showing. This should make the code go away.
It may or may not come back. If it does, clean the coronas.
It is necessary to remove the drum assembly in order to access the charge corona.
The EP3050 originally came with a self-replacing charge corona. It actually had a small spool of corona wire in the charge corona assembly, along with a small motor that advanced the wire every few thousand copies. This was prone to malfunctions, and there was a retrofit kit which replaced the whole thing with a conventional wire.
If you still have the code, and have no idea what I'm talking about, then it is probably time to call a technician. :-)
You will need to call an independent, as Konica Minolta no longer supports this model.
Posted on Nov 13, 2008
saxmansaxman
  • 177 Answers
SOURCE: BONJOUR J AI
This error code is due to the filters on the suction fan take of the backpanel on the machine and check the filters are cleaned you should be able to feel the air coming out from the slots that are cut out on the back panel when the machibe is in operation if the filters are clean look to replace the suction fan
Posted on Feb 02, 2011
  • 10 Answers
SOURCE: mesin masih tetap bisa digunakan,
Waste toner full & reset waste toner counter
Posted on Feb 15, 2011
How do i solve my minolta copier cspro ep 1054 printing blank document
check the transfer wire assy. located under the drum. might not have a good connection or the High Voltage unit is bad. That is a very old machine.
Apr 03, 2017 | Minolta Office Equipment & Supplies
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Minolta CSPRO EP 3050 CODE ERROR C0072
Sir/Mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Aug 28, 2013 | Minolta EP4000/5000 CS/PRO Copier
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
Minolta cspro ep 3010 code c0924
On the control panel is there a little icon like wrench in the left hand corner of the screen, if so touch it then new screen will appear, once new screen appears open close the front door to reset the code
Mar 16, 2011 | Minolta DiALTA Di520 Laser Printer
Detaile of Code of Minolta Ep 6001 coper
pleas send me cs pro 6001 code 611 salvation
Feb 12, 2011 | Garden
BONJOUR J AI UN PROBLEME AVEC MON PHOTOCOPIEUSE MINOLTA CSPRO EP 5000 QUI EST LE SUIVANT CODE C0040 JE VOUS PRIE DE BIEN VOULOIR ME GUIDER VERS LA SOLUTION ET MERCI BIEN
Jan 14, 2011 | Minolta EP4000/5000 CS/PRO Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
56 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
