Question about Winco 5500 Watt TriFuel Power System w/ Electric Start Honda - PSS6H
Power loss hi, i have a ryobi 950w generator, 3 months old.. i only use this to run a vacuum cleaner at the carwash. both were bought new and worked fimne till last week.. the generator kept tripping after switching on the vacuum, tried another vacuum but still the same yet any other power tool, even a huge hilti drill works fine. now, i removed the trip switch and it works fine but with lesser power. any help?
    Top Expert:
  • Winco Master
  • 44,589 Answers
950 watt is very small. Most electrical appliances need 1000watt to operate so if the vacuum cleaner is 1000watt then the gen set will trip. Check the drill as it is possibly 850watt which the gen set can handle. It all has to do with the wattage of the equipment you intend to run from the gen set
Posted on May 09, 2013
Testimonial: "i have also thot about the same thing, strane thing is i tried another generator of the same size n it works tops. the 950 that i have worked just as good wen i bought it, maybe the motor is on its way out?"
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
My ryobi 2200 generator rebs hi and low over and over it works but i feel it might turn off
You need to clean carburator. The bowl float opens and closes the pin valve. The float may have a leak, if gas inside float, it needs replacing. Or the valve is sticking. Get a good carb cleaner product at parts store. If its very bad you may need to take carb apart and soak the parts to clean them. Make sure you are turning off gas valve when not in use. You should turn off gas valve and let the motor run out of gas before using kill switch to drain gas from carberator each time its run. Then this won't happen. If no gas valve, buy one and install. Its worth it.
Jan 20, 2014 | Electrical Supplies
Hi there Our vacuum cleaner exerts no pressur and it doesnt **** anything from mat,, it is just 4 months old bt we have missed the receipt,, cadsn u please help us? thanks and regar
Check your filter/bag especially if you've used it to clean fine particles; they will tend to clog the filters or bag and cause loss of performance. It the filters/bag are good and/or new, check for an obstruction in the hose or suction tube.
Jun 30, 2011 | Vacuums
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
A friend living in the country bought a Ryobi RG-950 generator. She wants to run 1 of her 2 computers or a TV 1 light at night and asked my advice. I told her that running any electronic equipment off a...
It's best to run all electronics through a UPS and surge protector. Small generators like the RG-950 are really for small power tools and lighting. The Ryobi RG-950 is only rated 650 watts which really means about 450 watts (70%) for continuous use. In general, a basic desktop or a laptop should be OK. A TV up to 25 inches and a 100w lamp, should be OK. If you try doing both at the same time, expect smoke followed by lights out. A UPS and Surge Protector are a must on small generators due to their poor voltage and frequency regulation. The UPS should be a good quality one that deals with Brownout, Overvoltage, and frequency deviation. ALWAYS USE A SURGE PROTECTOR!
Sep 05, 2010 | Winco 5500 Watt TriFuel Power System w/...
Has gas in carb but will not transfer gas to engine
if gas is in carburetor but won't transfer to engine, try to spray down the carburetor 'tube', choke plate and jets with a carburetor cleaner spray. The jets are probably clogged, due to lack of use.
Also, you can try putting carburetor cleaner into the gas tank, a little bit.
If this does not immediately work, then a carburetor rebuild is required, where new jets are put in, and passageways are blown out with compressed air and sprayed with carburetor cleaner in a disassembled state.
If you store the unit with old gas for 3 months or so, then Stabil Gas treatment is recommended. If it's longer than 3 months then the carburetor should be drained or the engine run until it is out of gas in the float bowl.
This may seem a little funny, to do all this, but if one does this, then less expense for carburetor rebuilds can be avoided, over time.
Good luck on this repair.
Jul 18, 2010 | Coleman Powermate Premium Plus 6250W...
Roomba 550 was plugged & docked in for 3 wks without being used (on vacation) & now it won't work or charge. Unit is 3 months old.
The battery sounds like its dead.. Leaving it on a constant charge is actually bad for the battery. Sorry to tell you but you need to either get a new vacuum or take it back to the place you got it and have them take a look at it and perhaps replace the battery.
With the money you spent of that "vacuum" you could of bought a much better vacuum cleaner that would last you much longer.
Also, if it's only 3 months old I'm sure there's some kind of factory warranty in place for something like this. Give the manufacturer a call and see what's up.
Hope this helps you
Mar 23, 2010 | iRobot Roomba 560 Robotic Vacuum
Ryobi PCN 4040 will not start up
When I was going to college I worked at a tool rental center and learned may tricks about tools. At this rental center chainsaws were seasonal thus sat in the warehouse probably as in your situation. Well one is supposed to store a chainsaw without any fuel and discard any old fuel mix because it will not keep. To easily start a saw that was in storage we would install a new spark plug, add fresh fuel mix and spray carburetor cleaner directly into the carbureter to get it started. Once started fresh fuel would be drawn into the engine from the tank and keep running. If you forgot to drain the old fuel, do it now and use the trick above. For best results, always use a fresh plug. Enjoy
Dec 15, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Winco 5500 Watt TriFuel Power System w/ Electric Start Honda - PSS6H Logo
168 people viewed this question
Top Winco Electrical Supplies Experts
John Trevino
J.D. Browning
J.D. Browning
Tom Chichester
Are you a Winco Electrical Supply Expert? Answer questions, earn points and help others
