Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Toshiba 46HM84 DLP Black and white pattern..
I have a Toshiba 46HM84 DLP television. At first, I got a red flashing, solid green light that indicated I needed a new lamp/the lamp door wasn't seated. There was no sound and no picture. However, recently, when I powered it up, the TV actually turned on. However, there is a black and white pattern (about 1 inch tall, 3 inches wide) that spans the entire screen. Changing channels, inputs doesn't change the picture (but the screen does go black for a second to signify it is changing something). Any ideas? Thanks, Mike
    Sergeant:
    Champion:
  • 375 Answers
Contact your dealer for service flashfor this symptom.(light tunnel)
Posted on Sep 05, 2007
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
Toshiba 62 inch dlp tv keeps flashing green and will not turn on
green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications.
Good luck..
Aug 29, 2011 | Toshiba 62HM195 62" HDTV
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 46hm84 no picture, buzzing sound green light flashes, tv restarts
You may want to check the Lamp. It will give you this same symptom.
Hope this helps,
Skyassoc
Oct 24, 2009 | Toshiba TheaterWide 46HM84 46" Rear...
No sound no picture and new bulb red and green flashing lights on power up.....
The problem is either the lamp ballast or the light engine. My guess is the ballast. Part cost ranges between about $75 to $150 depending where you get it. If you're handy you can replace it yourself. I posted the process elsewhere on this site for another Toshiba DLP question (I think it was for a 46HM84). Good Luck.
Jun 21, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
46hm84 toshiba problem
You will find that when the old lamp exploded, either it damaged the ballast unit or there are shards of glass stopping the cooling fan.
May 04, 2017 | Toshiba 46H84 46" Rear Projection...
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
i have a toshiba dlp doing that after research i found it to need a lamp replacement
Feb 01, 2009 | Toshiba TheaterWide 46HM84 46" Rear...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
291 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
