User and password default Cisco sap1602i air - Computers & Internet
2 Suggested Answers
  • 116 Answers
SOURCE: What's default password and user name for Actiontec GT704WG
Default username is admin.
Default password is password.
I hope this helps!
Posted on May 13, 2010
Testimonial: "Thanks for the right answer!"
I need password for Cisco Router model E1000. User name is Cisco41070.
This is not a default username for this router. you will need to reset the router to get back into it. There is a reset button to press to get it to its default configuration. Then the default username is blank and the password is admin.
Jul 28, 2017 | Cisco Computers & Internet
Forgot my password to my cisco router
On the back of your router is a 'reset' button. Use a toothpick or a pen to press it for approximately 5 seconds. Once this is done you can log in with the default user and password.
I can find the default user and password for you, but I'll need the model of your router to do that. However most likely the user will be 'admin' and the password will be 'admin' or the password will be blank.
If you need a list of cisco routers and their default users and passwords, you can find them here: CISCO Router Passwords
Aug 23, 2014 | Computers & Internet
Forgot guest pw on cisco e2500
If a password was set by user, no one else will know it if you forget it.
If the password needs to be reset to factory, so you can log in with the "default" password AND RE-SETUP EVERYTHING, then you'll need to reset the Linksys E2500 to factory defaults. You can usually do that via a special button or sequence of actions.
The E2500 manual will have specific directions for performing a factory default reset. You can download the manual for the E2500 from http://support.linksys.com/en-us/support/routers/E2500
Aug 08, 2013 | Linksys By Cisco E2500 DualBand WirelessN...
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
Mar 16, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
I forgot to change the default public credential User: cisco and pwd: cisco. Un fortunately I did restart the router. I would like your assistance to gain access to the router or to reset it back to...
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 11, 2011 | Cisco (1841) Router (cisco1841)
Hi when i reset cisco srp521 router, what will be the username & password for admin user. thanks aks
The default username is admin.
The default password is admin.
that's the default passwords. it does depend on the type of reset whether you will still have the old passwords or not. be that as it may i'm also including the user manual for you
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
i do hope this solution helps you
thanks
robert
Mar 03, 2011 | Cisco SRP 500 Series with 10100 Mbp ...
Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
Can not login on con 0 port (not text), lost
default username and password for all router are
admin and admin
or
admin and password
try these two combinations
else try link
http://www.cisco.com/en/US/products/ps6187/index.html
Oct 03, 2009 | Cisco 1811 Router
Password
try these combination's:
User password
cisco cisco
admin password
admin admin
admin 1234
Feb 12, 2009 | Zonet Computers & Internet
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
