I have just bought some Tannoy MX1 Speakers to hook up to my AVR-2500 receiver & am wondering what quality/AWG/Impedance rating etc Speaker Wire I should purchase to connect them?
That's why I asked as a "shop techie" was unsure as to what spec should ultimately be with the equipment I have.That's why I asked as a "shop techie" was unsure as to what spec should ultimately be with the equipment I have.
You can't post conmments that contain an email address.
It depends on the speaker and receiver inputs/outputs. If The speakers have bare wires, and the receiver has spring clamps, you are in luck! Check out what I mean by spring clamps in the image linked below. If you can give the model number of the receiver and describe the wires coming from the subwoofer, I can help a lot more.
Luk, Home stereo speaker wire size. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Speaker Impedance
8 Ohm Load
6 Ohm Load
4 Ohm Load
Wire Gauge
Distance (ft)
Distance (ft)
Distance (ft)
18 AWG
10
8
5
16 AWG
14 AWG
12 AWG
60
45
30
10 AWG
Above chart by Audioholis Speaker wire guide Speaker Cable Gauge AWG Guidelines Recommendations 5 Myths About Speaker Wire
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Check the gauge on the wiring. For that size amp you would need to use 0 AWG wire for the power, the speaker wire is just signal wire so you want to use regular speaker wire. (I have 12 AWG setup for speaker wires) What the two power ports (Neg and Pos) do is increase the amount of flow. Two power wires to distribute the flow of the current so you don't burn up your wires if your pumping too much juice. I started off with this exact amp running a single 8 AWG and split it into two and it burned up and blew a fuse after a couple of huge bass hits. So proper setup would be.... BAT(+)---FUSE HOLDER(60AMP+)---DISTRIBUTION BOX(30AMP+)====AMP GND(-)===AMP -- would be 1 wire pref 0 AWG splitting into more 0-4 AWG == would be the 2 wires (Yes two ground points in separate locations would be better) Thus finalizing you have a proper setup. Be careful you don't burn out your alternator, this bad boy can cause some serious problems with a lower amp alternator. Let me know how it works out.
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
I had this same problem and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
Speaker Impedance:
When speaker systems A and B are used separately, speakers with an impedance of 6 to 16 ohms can be connected for use as front speakers
Be careful when using two pairs of front speakers (A + B) at the same time if their impedance is less than 12 ohms.
The protector circuit may be activated of the set is played for long periods of time at high volumes with an impedance lower than specified are connected.
