Question about LG Electronics Tone HBS-730 Bluetooth Headset - Retail Packaging -
Can't control sound volume
Paired with Blackberry Plauybook to listen to music, but I can't control the volume, there is only LOUD and I mean LOUD, I don't even have the plugs in my ears and I hear it clearly. I can't control the volume on the Playbook either, it's as if it's cut off. Am I stuck with a lemon. I've used it a few times with Blackberry Curve and there's no problem. Please help before I go deaf. Thanks.
2 Suggested Answers
SOURCE: Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Posted on Jul 19, 2010
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Cant listen to music on my Blackberry Pearl using HT820
I'm not familiar with Bluetooth and Blackberry's but I think you need a driver or you need to "sync" your media player on your Blackberry with your headphones.
I'll do some research and get back to you.
Feb 20, 2008 | Motorola Mobility HT820 Wireless / Cable...
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Feb 08, 2015 | Samsung Radio Communications
The music volume is low
Depends what you're listening to. If the sound can be turned up in other locations in your computer, then the encoding of whatever music that you're listening to may just be low. Turn up your volume from both your master volume on your computer, and from the application from which you're playing the music.
Jun 04, 2011 | Computers & Internet
Remote funtions on LG HBS200 do not work with Blackberry Tour
When you go into the Tour's Bluetooth options, you can view which services are available for each paired device. Check the headset's properties and make sure all of the available services have a check mark next to them.
If that doesn't solve the problem, let me know and we'll try to find another solution.
Oct 05, 2009 | RIM BlackBerry 8100 HS-655 Bluetooth...
My ringtone volume sounds too low for a blackberry curve.And my friends have the same phone and its louder!Im mad this phone is brand new!!
Just_Bobz is correct and incorrect at the same time...
Not all blackberry curves are set up the same nor do they all have the same "theme" (layout)
For instance the T-mobile Blackberry Curve (8120) has a different theme and therefore the sound option is not in the upper right hand corner like the Alltel Blackberry Curve (8330) default theme.
My suggestion is to find the volume control icon on your curve (or the volume themes as I like to call them). When you click on the speaker icon you will have the options for the different volume themes such as Loud, Vibrate, Quiet, Normal, Phone Only, and Off. Click on whichever theme you will be using on a regular basis to activate it.
** Another area where Just_Bobz is incorrect… just because you have put the volume theme on Loud does NOT mean that the phone is on its loudest possible sound setting!!
If you go back into the volume themes, all the way at the bottom there is an Advanced option.. If you click on Advanced, highlight which ever theme says active next to it and click your trackball to open it ... you will then have the option to change the option for any and all alerts on the phone (ie email, phone, mms, sms, bbm. ect.) Under each of the different options there is ANOTHER sound option for low, medium, high, ect. (and there is an in and out of holster setting
Just because your volume theme is set to Loud.. does not mean that the phone is truly set to loud!!
Feb 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
hold the volume button untill the speaker immage @ the top highlights red then use the << and >> pads to turn it up or down
Jul 22, 2008 | Kaser Corporation Mambo Mano Digital Media...
Can't adjust the earphone sound
Use the side buttons to lower the master volume, when your in media mode listening to your music, you have to use the side buttons or flip it open and use the side buttons by squeezing your finger between the big screen and the keyboard, they diodnt think that part out to well.
The ear Piece volume control your talking about only pertains to when your actually on a call.
Stupid set-up i know.
Dec 31, 2007 | LG enV VX9900 Cellular Phone
RIM has a new OS for the 8100 pearl (OS 4.3). This OS supports A2DP streaming which is necessary for listening to music with bluetooth headphones. The OS is out in beta version now and supposedly available on bit torrent. I hear that AT&T will release the OS for their phones in April or May.
Nov 06, 2007 | Motorola Mobility HT820 Wireless / Cable...
LG Electronics Tone HBS-730 Bluetooth Headset - Retail Packaging - Logo
130 people viewed this question
Top LG Radio Communications Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
