Question about Eureka 955A Complete Clean Bagless Canister Vacuum Cleaner
Eureka Complete Clean 955A loss of suction
Vac only 3 months old, used twice and now the suction at the bottom head is gone and the suction is weak in the hose. I took apart the bottom head and the duct were the dirt goes is clear, and the beater bar is clean with a new belt. I checked the hose and it's clear. The red filter light is on so I followed the directions in the manual and cleaned the filters and emptied the dust cup, that did not work either. The unit is starting to over heat also.
5 Suggested Answers
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
  • 22 Answers
SOURCE: eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Posted on Feb 03, 2009
  • 8 Answers
SOURCE: my eureka smartvac 4870 has no suction at hose or
your eureka has no suction kuz the vacum hose needs cleaning
Posted on Nov 29, 2009
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
Loss of suction
If it is running and you have no suction, there has to be a clog in the dirt path. To clear it, start at the head of the vacuum (where the dirt goes in) take apart or disconnect everything you can along this path until you arrive at the bag or cannister. Take pics with your cell phone so you can reassemble it. Hoses: run a broom handle through all hoses to assure they are clear. If you have a shop vac or similar, try applying vacuum to all parts of your disabled vacuum in reverse. Are there filters on your machine? Make sure they are clean. You probably don't have hoses connected, but if you do, check them as I said.
I pick up vacuums along the road all the time. Very few are more than a few months old. All of then have a clog in the hose or elsewhere in the dirt path. I clean the path and sell the vacs for a slightly discounted price. VERY rarely is it a motor problem.
I hope you find this comment helpful. Here they are in under 5 minutes. Thanks for using FixYa.com
Jun 27, 2011 | Kirby G5 Bagged Upright Vacuum
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Need to replace belt on Eureka Powerline 12.0 vac. Screws look like Torx head or something on bottom of vac. Are those the screws that need to come out for changing? If so, what size do I need?
No, do not remove the torx head screws for a belt change. If there are any screws that need to be removed for the belt change, they will be phillips head. What is model # of vac??
Oct 04, 2008 | Eureka Vacuums
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Aug 11, 2008 | Eureka Vacuums
Eureka Central Vac-Sweeper -Model B1501
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 | Vacuums
Eureka 955A Complete Clean Bagless Canister Vacuum Cleaner Logo
77 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
