Question about Apple iPod nano
Ipod won't go to main menu when menu clicked
I press menu, takes me to another menu, but won't let me go back to main menu if needed. Also, ipod is skipping songs that are selected, moving on to different song. I need help soon. Going on 14 hour plane ride and would really love to have the ipod with me!
  • 3 Answers
The best option would be to restore the iPod's software. To do that, plug in the iPod to your computer and open iTunes. Click on your iPod in the left hand column and click "Restore" under the iPod information. Please note that all songs will be cleared from the iPod. Once that is done, load the songs back on to the iPod and see if the problem is solved.
Posted on Aug 11, 2007
6ya staff
SOURCE:
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Ipod classic won't turn on, battery with lighting bolt when plugged in.
You probably need to reset your IPOD. Here are the directions:
1. Unplug the IPOD from the power source.
2. Slide the hold switch or button to HOLD and back again.
3. Then press the MENU and CENTER buttons at same time until the Apple logo appears.
You should be back up and running. If not, try again and remember to make sure you press MENU and CENTER buttons at the SAME time and continue to hold them down as long as it takes for Apple logo to reappear. I once had to hold them for more than a minute before an IPOD touch would reset.
Dec 01, 2012 | Audio Players & Recorders
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
How do u unlock volume on ipod
  • From your iPod's main menu scroll down and select 'Settings > Volume Limit'
  • Enter your 4-digit combination numbers you used to set the volume limit using the scroll wheel to select the numbers
  • Press the 'Center' button to confirm your password
  • Use the Click Wheel to move to the maximum level on the volume bar to remove any restriction on volume
  • Press the Center button to confirm the change
What To Do If You Can't Remember Your 4-Digit Password
  • Download and install the latest version of the iTunes softwarehttp://www.apple.com/itunes/download.
  • Open iTunes and from iTunes interface click on 'Users iPod' under 'Devices'and click on the 'Summary' tab where you will see information about your iPod.
  • Click on the 'Restore' button. Restoring your iPod will take a while so be patient. Be warned though all your data will be lost from your iPod but your iTunes library will stay intact.
  • After restoring your iPod, unplug it from your computer, and reconnect it once again.
  • All your songs and files will be downloaded back onto your iPod. If it doesn't start downloading automatically, go to 'File > Sync iPod'.
Jan 24, 2011 | Apple iPod nano
It will come on to the main page but the click wheel won`t move
Look on top of the ipod to see if the switch color is orange, which means the ipod is locked.  Switch the thing the other way to unlock.  Also, make sure you got the latest software updates for the ipod to fix click wheel sensitivity issues.  You can also do a reset- push the center button and menu button at the same time until the apple logo appears.  Then you can release your death grip on the thing.  Take the thing back to the store if your within your warranty and have them deal with it if you still got problems.  Cheers.
Nov 24, 2009 | Apple iPod MP3 Player
IPod Touch Automatically Reverts to Main Menu Screen
you need to restore your ipod touch by connecting it to your computer and clicking restore. make sure you have backed up your ipod touch before you do this or you will lose everything on your ipod touch.
Jun 16, 2009 | Apple iPod touch
My ipod won't let me go back to main menu and i can't turn it off
The easiest solution is to restore your ipod. This will erase everything on it and reset it back to factory defaults. You will need to sync when complete to copy your songs / apps / settings back over. Make sure you've synced recently before you try this procedure.
Press and hold the power button and the home button at the same time. Continue holding. Your ipod touch will power off. Wait a few seconds, and power it back on. Is it working now?
If not, turn your ipod back off then press and hold the Home button. Reconnect the USB cable to the ipod touch and your computer. When you reconnect the USB to ipod, the device should then power on.
Continue holding the Home button while it starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message. Click OK and iTunes will restore your ipod to factory defaults and re-sync your data.
If this is helpful, please rate me accordingly. If not, let me know and I'll see if I can offer other suggestions.
Mar 29, 2009 | Apple iPod touch
Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
Jan 18, 2009 | Apple iPod nano
Restoring my Ipod!
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog
http://www.pchelpforanyone.blogspot.com
Mar 13, 2008 | Audio Players & Recorders
Changed language to french!
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
Feb 09, 2008 | Apple iPod nano
Apple iPod nano Logo
102 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
