Brc1c51 daikin i have brc1c51 controller and the motherboard in fhy35-125bjv1.bve door. or guide me the interconnection
3 Suggested Answers
  • 47 Answers
SOURCE: i have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Posted on Nov 11, 2009
hvac1960
  • 2133 Answers
SOURCE: rent a house with a daikin brc1c51/61 with no
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Posted on Dec 30, 2010
I have daikin n81 air con, its showing f3 code on the control panel what dose this mean
f3 error is a bad thing, it means excessive compressor temperature in outdoor unit. Overheat condition outdoors. Please find a daikin factory authorized service tech in your area to come check it out. These units are awesome when they work, but when they don\'t, normal HVAC techs tend to not want to touch them. They will try to sell you something else. Or even worse, they want to vacuum and refill them for no obvious reason. A 200 dollar maybe fixit.
The daikin units work more like a tv or a car than the old school air conditioners. They have remote controls and service menus and scan tools and such. A veteran daikin tech can diagnose your system fast and give you a wise estimate of what you need. You may just have a leak, or there might actually be something mechanically wrong outdoors.
I would not push my luck and try to run the unit with this error code. Please don\'t let the magic smoke out of your system.
please mark my answer helpful.daikin ductless
Jan 04, 2015 | Heating & Cooling
Daikin brc1c51 61
I would like to know this too - I have no idea ??? Is there a remote control that needs to be paired with it or something - I only have the wall panel .......
Feb 16, 2014 | Heating & Cooling
When powerd up i get 1 long beep after another,what could it bve?
Each motherboard BIOS has a series of beeps meaning different things. If you are getting two long beeps then I recommend looking up in the pdf manual in the FAQ or troubleshooting section of the guide. It could be anything like a heatsink not properly inserted, or the cpu cooler fan is broken or not plugged in, the memory needs reseated, or graphics card is not compatible, etc.
Jan 02, 2012 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Now symbols:
4. Sun- Heat
Dec 30, 2010 | Heating & Cooling
U4 System transmission between indoor and outdoor units Daikin
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Will the D915GEV support window7
Yes: Windows 7 can be used with this board.
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Here's the specs on the D915GEV
(See PDF Manual)
Click here:
D915GEV Technical Product Specification [PDF]
The Intel 915G chipset consists of the following devices:
• Intel 82915G Graphics Memory Controller Hub (MCH) with Direct Media Interface (DMI) interconnect
• Intel 82801FB I/O Controller Hub (ICH6) with DMI interconnect
• Firmware Hub (FWH)
The MCH is a centralized controller for the system bus, the memory bus, the PCI Express bus, and the DMI interconnect. The ICH6 is a centralized controller for the board’s I/O paths. The FWH
provides the nonvolatile storage of the BIOS.
Supported Memory Configurations.
Up to : • 4 GB maximum total system memory.
Processor:
The board is designed to support Intel Pentium 4 processors in an LGA775 processor socket with an 800 or 533 MHz system bus.
Note: All processors available for this board are in excess of the 1 gigahertz (GHz) minimum requirement for Windows 7. (see here) http://www.intel.com/support/motherboards/desktop/d915gev/sb/CS-026957.htm
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 08, 2010 | Intel D915GEV Motherboard
I have daikin air con brc1c51/61 showing error code J2.
Nov 11, 2009 | Heating & Cooling
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
