Question about Refrigerators
Goldstar refrigerator 111cgs
How mutch capillary for this compressor (vs24)
2 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Capillary tube replacement
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Posted on Sep 02, 2008
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
Refrigerator wont cool
You laid the refrigerator on its side? If the refrigerator has been moved in this way oil from the compressor flows to the evaporator and blocks the capillary tube. Just leave the refrigerator standing for about tenty four hours. Then try plugging the power on for about ten minutes at a time until the compressor is able to continue running and the capillary tube begins to clear out the oil that was cause by laying down refrigerator. If this is the problem you simply need to plug in power for short times until the compressor starts again without restriction of oil in capillary tube. Do not plug it in and leave your refrigerator while there is back pressure and compressor will not run. That could cause damage to compressor. Have comments or questions please ask, Thanks Sea Breeze
What is the model number? Was the problem caused after moving fridge?
2_26_2013_10_34_20_pm.jpgHelp
Feb 26, 2013 | Whirlpool Refrigerators
Hi, I bought my Frigidaire refridgerator in June 2002. Within a year the compressor had to be changed. In November 2009 the compressor died again. A new one was put in. Last week it quit again. The...
Who is performing this service ? The line he is referring to is the liquid (capillary tube) suction line which is welded together for proper heat exchange. If that is the case then this should be addressed by the manufacturer. Was the system properly evacuated and a new drier installed ?
Was the condenser clean ? The newer refrigerants along with overheated systems cause any moisture in the system to release salt which mixes with compressor oil. This sludge clogs up the capillary tube stopping refrigerant flow.
Jul 13, 2011 | Frigidaire Refrigerators
Freezer and fridge not cooling
compressor not on most likely.listen for a low hum inside or low down close to the floor in front of it.If no hum its not on.depending on age you can install a hardstart for it and get more life out of it.
Sep 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigator not cooling coils clean and compressor working
check defrost timer control on older located on bottom by the condenser coils look at elect diagram to see if one is hook up
Sep 24, 2009 | GE Refrigerators
NO COOLING IN FREEZER OR FRIDGE SECTION
yoiu are correct that the unit sounds like the compressor is low on charge and or has a clogged capillary tube. Whenever the condenser coils get rael dirty theres a chance that the capillary tubes will clog up with oil. That is the raeson that I personally do not like the refrigerant r-134a and prefer another one called hotshot or r-414b.
Apr 05, 2009 | Refrigerators
Freezer and refrigerator not cooling.
Are you sure that the compressor actually runs, if it does start up and run, I would suspect a blockage in the refrigerant tubing around the filter drier where it is reduced to capillary tubing. If the compressor is just trying to come on, then switching of, I would try changing the starter relay first.
Mar 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 02, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
